Black Hole Vu+ Duo 1.3.9.2 (update)
Hi,
I installed the update and rebooted Vu+ as per the instructions above. Unfortunately the web tv is still not working. The streaming starts for a second on pc and then the picture freezes while there is still voice.
I have the image installed on internal flash memory and am using vlc player .
Do I have to do anything else to get it working.
TIA
Hi,
TIA
I've installed the update yesterday evening and webtv works correctly who use the VLC Firefox plugin.
I don't test the tv stream directly with vlc.
Hello zupy so sory for my late.This is my crash log.I did nothing but after restarted, the box went to green screen and i had to delete DDsub folder in my box.Thanks for your help.Best regards...
Thanks your reply. I am using Google Chrom browser and apparently does not have VLC plugin. I switched to firefox and webtv now works correctly using VLC Firefox plugin.
Thanks again for the tip.
Best regards
Small issue. On web interface, web remote should have a picture of a VU remote and a corresponding image map with VU remote commands. Now it shows a Dreambox remote.
Did you have a old sub player before this?
Best regards
yes... funtion well with Chrome and VLC
with the update thats ok guy!
Excellent image, like all others BH images, and excellent support, thank you very much for your amazing and hard job.
