Black Hole Vu+ Duo 1.3.9.2 (update)
Why doesn't streaming with m3u file in VLC work with Blackhole? sometimes it works but most times it errors out with 502 Bad Gateway
Hello,
I have a problem with this image.
I have bh 1.2.9.2 in flash
in a usb cf card reader i have a CF with meobot installed in it
some times, no allways, when the vu+duo start apears in display the message "reading usb...." and never start. The remote control don´t work and the solution is turn off the vu+duo pressing the back button; then i start again and works fine.
any idea??, is the problem meobot?
sorry for my poor english
Format CF in FAT32 (PC).
Place than in USB (BOX)
Restart
blue Button, blue Button, Devices Manager
Format CF
Mount CF
Restart
Hello,
I've the same problem with a pendrive 8Gb and my DVB-T tuner.
When I've some spare time I will test if is the hub or my pendrive to make problematic the box boot ....
hi
i have two problem.
1. i instalel BH 1.3.9.2 ON flash and multibuted . i instaled this image on my usb because i have miultibuted it.
and i have instaled vix image and i have problem: some chanel hd havent SQ on vix but this chanel hd have SQ on BH !!!!!
2. when i have started mkv file that it is on my hdd audio and video is not set
but this problem is not in vix image
epg.dat is downloaded to hdd but channels show no information on rytec skyuk, dtt from rtenl is working perfectly on nova-t usb stick.
I have a problem with vcl in the PC, when I reproduce of satellite it is not cut but if I use the tdt it is cut to 5 or 10 minutes.
Which can be the reason?
Hi,
Is there an update online feature for Black Hole Vu+ Duo 1.3.9.2.
Where can I find it.
TIA
At the moment there is not an update online service for BH images.
its posible that the problem is meoboot??, can i uninstall meoboot???
If your box don't boot with pendrive plugged in, Meoboot is not the problem but your pendrive or your hub usb, if you are using this device of course.
In my case the problem is with a CF reader and CF card. I try now with other CF Reader.
With the first CF reader the box detect the device as USB. With the second CF Reader the box detect the device as CF Reader.
I will tell you tomorow the result`s of this change
EDIT: Since one day of test, the problem never apearance. It seams that the problem was the CF Reader (imation flashgo card reader)
hello zupy.I have the old problem with ddamir subtitle.After i installed DDamir ,it work fine but after 2 or 3 horse box goes to crash.dose fps work fine? it seems not work .Thanks for you help.
Hello gays i also have a problem with play mkv file.It seems the video and audio in this format don't match fine.
