Black Hole Vu+ Duo 1.4.2 Multiboot
I have static IP of 172.16.20.2 configured but when i run ifconfig from shell it shows DHCP IP, this must be bug?
root@bm750:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:1D:EC:01:AF:8D
inet addr:169.254.238.138 Bcast:169.254.255.255 Mask:255.255.0.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4929302 errors:0 dropped:0 overruns:0 frame:0
TX packets:5029238 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:635172505 (605.7 MiB) TX bytes:464545015 (443.0 MiB)
Interrupt:16
just installed the new version of the image and trying to install the DVB-T driver af9015 get this message ????
With the previews image was working fine , is there any changes of the driver ?
I've restored the previous drivers.
Please re-download them from DTT Panel using Red button.
The current packages have UsbTuner 0.2.6 inside.
for some reason its downloading the 0.2.8 version again , do i have to do something else , get the same message after pressing red button and after that yellow to activate ?
You should re-select the driver with red button, activate with green and I expect you can see UsbTuner 0.2.6 version.
Sorry, I have trouble downloading the image.
probably is a problem only mine, but someone can check if there are problems on the server?
thanks oscartec
thanks oscartec
I've downloaded USB and NFI version from the first page of this thread and all works correctly.
sorry m8 for bothering you but could you please upload the 0.2.6 drivers for aver media volar black hd A850/HD+ A850+ , these r the drivers i need for my stick , those r the one that my stick use to work and Not the A867
Thanks in Advance for the Help
This evening I will upload the old package you require for Duo box.
Sorry for the inconvenience my friend.
