Black Hole Vu+ Duo 1.4.2 Multiboot
Hi all, i wanted to install cccam_info plugin manually. I imported enigma2-plugin-extensions-cccaminfo_svn-2940-r0_all.ipk in temp directory. Then went to module in my VU+duo to install ipk manually. Everything installed correctly. But I am not able to find the plugin anywhere. I have BH 1.4.2 image. Any suggestions? Thanks
We don't support CS plugins or CS software in any forms.
I know that the plugin you have mentioned is purely informative but the argument is forbidden in this board.
If you can't find the plugin in the "Plugin" section of Main Menu is possible that is not 100% compatible with the image or is designed for another 3rd party image.
hi
yes i'm once more - i have a box with deep standby
test with image bh 1.4.2.
zap to radio (not internet radio) then back to tv (no green screen) then zap to another tv channel - green screen
try it with reboot many times - always green screen
new flashing 1.4.2 - the same green screen
by a friend (box without standby)
image bh 1.3.9
zap to radio (not internet radio) then back to tv (no green screen) then zap to another channel - green screen
i think thats a bug
I have often on last 2 images (1.4.1 and 1.4.2) greenscreen or restart in normal watching tv. This is last crashlog. I tried with reflash but same problem.
Very interesting....were those crashes happing to the image in the internal flash or with the image in the MB(USB)!
Could you please post a case test to reproduce your crash? Specify also if your image is in flash or multiboot.
Thanks
Thanks
My last image (1.4.2) is in flash without meoboot ! I made it,because on 1.4.1 I had a meoboot mounted on usb and had possible cause of problem.
Now, in flash without any. I had crash yesterday when I normal watch tv,just greenscreen and crash. In some cases before I have greenscreen in normal fast zapp, changing between channels.Also I had greenscreen when I have JUST 3 EPG providers active in EPG, "sky it", "sky uk" and "ex-yu" . I think this problem with epg need to be fixed in next release of image,because 3 providers are not much providers.
If You need some other informations, tell me.
Regards !
I realy have a problem,again greenscreen...Now when EPG try to update, JUST 1 provider ! :cry:
Here is crashlog.
Where do U save epg data in HDD ? or some where else and if U now have the image in the internal flash , did U remove the USB or still use it for storage!
Hello friends!
I have several questions about Device Manager.
Why USB-stick stopped automatically mount the directory /media/hdd?
Autofs daemon already exist, but not work correctly?!
Very uncomfortable every time you connect the USB-stick completely reboot receiver. Is there any solution?
Yes, I save epg data on HDD. What is a problem ? I always use hdd for epg data. USB is small. I wrote above, I use BH ONLY in flash. I tried without meoboot and mounted USB, same problem.
I've read the the crash log and it says your HD is ideal and repeatedly the crash happen after that, I think when it try to save epg data on it!
I do not have much experience in crash logs, but it looks like there is a problem with HD formating or mapping !
I would recommend that U do factory rest and start with clean image and then MB on USB with the same image!
I always use MB external flash and make swap file on the USB , never have a crash except when I put mod skin or testing a new plug ins which may be not compatible with the BH image!
Rgdz
a911
@a911
My epg data went to hdd. HDD is linux formated (on vu+duo) and mounted normal. I did not had problem like this on BH 1.3.8 and older...
This image is new, I reflash it before 3-4days and I realy don't see any reason for factory reset. I have clean image with 2 plugin, subtitle player and info...that is all.
I did not understand You about image on usb, You have BH in flash and BH on meoboot on USB ?! Why ?
scaricando il file usb mi da un file di 6 mega zippato corrotto
Prova a riscaricarla.
Io ho appena provato il file usb e viene scaricato correttamente e unzippato senza problemi.
Magari ci sono stati problemi in fase di download.
PS. siamo nella sezione inglese, bisognerebbe scrivere in inglese, altrimenti c'è la sez. italiana.
Try to re-download.
I just tried the usb file is downloaded and unzipped correctly and without problems.
Maybe there were problems during the download.
PS. we are in the English section, you should write in English, otherwise there is a sect. Italian.
Hello at all. I have one question. I watch my VU on a PC monitor over HDMI. My problem was that when i turn the VU in stnandby the monitor don't go in standby. This works with the drivers from 03.12.2010. Can i use the drivers on the last BH? Thanks!
@a911
I have been using this method for along time , this way I keep my eternal flash intact, since I play and test other images for the fun of it!
Also U can use the HDD for MB , storge,,,,etc!
But my choice is the USB,,,if it is damaged , can be replaced easy!
Rgdz
a911
