Black Hole Vu+ Duo 1.4.2 Multiboot
THX
but i have problem yet
when i playe film on hdd (.mkv) audio is not set with video
why ?!!!
i have this problem with all image except vix image !!!!!​
thanks I have installed latest 1.4.2, but can not use backup image script - I have try to backup I get message "no box detected" . In 1.4.1 it is working without problem. any help would be appreciated.thanks
You can download and install Backup scripts from server and test.
yes & thx
Hi BH team!
Just want to report an annoying problem wich just started 5 of days ago, after installing suomipoeka plugin to bh 1.4.1
Aftef i transfered some .mkv files to my hdd via ftp, all of a sudden i couldn't copy or delete anything form hdd via ftp. Moreover, when i try to backup settings on the hdd i get the message: Sorry, your backup destination is not writeable. The problem is still present after i flashed to bh 1.4.2.
What can i do/? Other than format my hdd?
Thanks in advance.
No problems here .
If your problems started with suomipoeka . Try to remove suomipoeka plugin ??
After restart image .
Or install image agn.
Hi ,superb image but knowing the pitfalls of multiboot and how the receiver can be stuck on starting when going wrong ,can there be a sticky on how to use multiboot.
\\\\\\\\\\\\regards jrbmw
