Black Hole Vu+ Duo 1.4.2 Multiboot
Thank you for this fantastic image.
Just two questions re BH 1.4.2;
- Somehow "3 Multi EPG" on Channel Selection TV screen doesn't fuction when pressed 3. Nothing happens. However, "EPG > Blue" and "Long Blue > 2 Graphical Multi EPG" work fine.
- The skins for 1.4.1 on the server are gone for 1.4.2 (like beyonce etc). All the skins for 1.4.2 on the server start with "v0.11/v0.12 Only". Can I install them on Vuplus Duo?
Thanks
sse450 You can not use skin v0.11/v0.12 in BH 1.4.2.
If you have replaced the BhAddons.pyo then put your orginal BhAddons.pyo back for getting the skin for use with BH.
enclosed crash log.
This log has nothing to do with our image.
You have had problems with EMC plugin
(EnhancedMovieCenter)
Rgd MX
P.s
I have make short test with Enhanced Movie Center
and it seems to work, after a few crashes in creating trash folders (delete movies folder)
But we do not guarantee work of plugins, it's a job for authors from this plugins.
Only if you find some bug related to the image or skin and only if the plugin is made for current CVS.
But I'm not at all satisfied with this
Enhanced Movie Center plugin
standard in image works far faster and more stable.
This can only cause image crashes .
So do not use if you really do not need.
Thanks ,
If
TRUE
this plugin sucks, and it's not working fine at all.
I suggest you remove it from downloads.
Thanks,
If you find more plugins that do not work well pls write
because there are so many ,and we do not have time to test plugins.
I think we had a topic related to this problem .
Because bad plugins can cause someone serious problems with image.
@grimm70
I didn't replace BhAddons.pyo intentionally. Probably NabiloAddons_bh.tgz did that replacement. Where can I find original BhAddons.pyo?
Thanks
hi
after radio listen green screnn when i zap to a encryptet channel back to tv ? by i friend - he has the 1.3.9 also
i have the 1.4.2 - so i go back to a older image 1.5 it's much more stable - sorry 1.6 isn't the quality of the older one
greets nad218thx
hi to all ı want to learn how ı recording to usb in blackhol 1.42 image (where is recording phats)?
You have to enable expert mode in Customize menu:
Menu > Setup > Sytem > Customize > Setup Mode: Expert
Then, as wrote a911, you will find Recording Path:
Menu > Setup > Sytem > Recording Path
hi
greets nad218thx
Totally disagree with U...BH oe1.6,,,is very stable,,,furthermore ,I have done a test on what U claiming,,,switshing between TV and Radio,,,for few times,,,NO Green screen(crash)!
the cause of crashes, most of the time, come from:-
1-Plugins,,not suitable for E2 or BH oe1.6.
2-Incompatible skins...mod skins or not from the image server.
3-Loading Corrupted Back-up image!
Rgdz
a911
Rgdz
a911
If you have any crashes please put on forum this help developers in fixed bugs or plugins; skin develpers too help in work.
@bogdanm
98% of the time I do not have crashes,,,as I said BH images are very stable... from .12 till today,,,!
other images I put in my boxes are only for the fun of testing and then go back to my...:inlove: BH!
GNite
a911
Well today i install from 1.38 to 1.4.2. I have tried many different image like aaf,vti,vix,de,pp.
No one can compare i think. Bh working flawless.
Good work guys.
hi
OE1.6 Images are much more instable then OE1.5 Images thats the truth and the team here know this
all images today have problems with freezer stability etc. also bh
the best images at the moment are the older 1.5 from every team
but it's not the fault of the team it's the fault of vuduo / marusys and their drivers
it's my opinion and not a fight against the team or bh
nad218thx
Hi all, i wanted to install cccam_info plugin manually. I imported enigma2-plugin-extensions-cccaminfo_svn-2940-r0_all.ipk in temp directory. Then went to module in my VU+duo to install ipk manually. Everything installed correctly. But I am not able to find the plugin anywhere. I have BH 1.4.2 image. Any suggestions? Thanks
