Black Hole Vu+ Duo 1.4.2 Multiboot
Please do not post thank you post, use "Like" button in post #1
A small bug. If you press Menu - VCR Scart, it goes into scart modus.
But message on display do not scroll, and show "If you see this,"
I guess it should show some more. You need to press exit to get out.
Other than that image seems to run stable and good.
BH always a step ahead!
Fix CI module recognition problem at bootup????problem for me at bootup
Could you please more exaustive?
What CI module do you use?
What is the problem (CI not recognized, recognized but don't work, work if you re-insert it, etc).
It's difficult to try to help you without informations :)
Thanks!
Thanks!
This is no problem only one CI in polish site user test TNK HD and Polsta HD module and rpoblem is with:
1} Module works only in the top slot, the lower it falls, even SD
2} After leaving the "deep standby" module does not work although it was seen by the software - you had to pull / push.
3} In the lower slot with no problem running the module with TNK Conax. (as a second along with Cyfra +)
4} When user make restart gui module no work mast pull/push; if make reboot all work very good no doing nothing work from begined.
This was tested on orginal image and Pli on BH user begined test .......
I think this is no problem BH this is problem new driver
I think all this thanks just spoilers the thread.
Please folks for christs sake, just use the "like" button on the first post!
THX
but i have problem yet
when i playe film on hdd (.mkv) audio is not set with video
why ?!!!
i have this problem with all image except vix image !!!!!
libopen.so.0.0 error when installing some plugins. reason for this?
sample : enigma2-plugin-extensions-fritzcall
