Black Hole Vu+ Duo 1.7.1 Server Tuner
Hi,
have the same problem with every BH Image. When playing movie from hdd and press “OK” 2times (to viewing Movie Details, length etc.), box crashes!?
Hi,
What plugin do you use to see movies?
I think you don't use the Media Player but another kind of plugin to see movies.
This Fix was made by Swiss-Mad for SD and HD skin for EMC 3.0 beta489!
It may work , have not tested it,,,I do not Use EMC!
Thanx for Kiliantv & Swiss-Mad for the plugin and the fix!
RgdZ
a911
RgdZ
a911
I'll try soon and let you know. :)
problem of 2 antennas with one fixed and one engine, the engine tuner hooked up tosatellite and b is not always displayed on the screen moving.
reported crash
greetings :thumbup:
would it be possible in future updates, to be able to add folders in the RECORDED FILES list,
I had my vu + duo a while and in my list I had loads of thing which I recorded, I would like to be able to make sub folders etc, SPORTS, MOVIE, ENTERTAINMENT so I could move thing around, this would be very helpful. Hope you guys can do this in future updates, and aslo the possibility to password protect your movies list button, this would be very helpful, thank you
I have it working since many months. At that time I had probably Suomiopeka or how this plugin is called. But now I do not have it anymore. It works perfectly. Also with Ipod/IPhone apps. Now even in the web control page.
Very useful to separate the things of each one or different topics.
hello
blackhole 1.71 in multiboot it's possible ? with 1.71 in flash of course.
excuse my bad english. thanks all.
Hello,
I have 2 problems with this image:
1.- when i press a number in the remote it show in the screen but dont change to this channel, so i have activate the option that 0 go to 1 and erase history and dont sork too.
2.- in my list of channel hage labels like sports, so when i zap directly up and down the box try to enter in this pabel like a channel and show a error of satelitte.
I have to say that tdt and smargo work better than other images but media player are not friendly use (folders for example)
Thanks
Hey BH team, Flashed the new image couple days ago and boy it's great, thanks a lot for the great work!
I was very curious to see the new DVB-T drivers and tunner fixes. So yesterday tried dvb-t and all went pretty smooth. A867 device, scanned channels and it found all services. In previous images the snr was fluctuating a lot and it's now very stable.
It looked like all was perfect until I restarted the GUI (tried Master Matrix Elegance HD skin). Audio/video started to be out of sync and channels become quickly unwatchable, it actually lookes like a buffering issue where the stream would actually get stuck in a loop where it would go back a couple of seconds.
I tried a full restart and DVB-T stopped working altogether, 0 channel found during scan.
I had to turn off at the back of the receiver, unplug the A867 device, restart, do another scan and all was good.
Anybody else experiencing the same, Angelo, any idea?
Cheers
Hello,
Thanks
1) if you press a number but doesn't change channel it mean you don't have that channel number in prefered, try to reload settings.
2) check tuner config.
I agree with you, i don't like media player. :)
