Black Hole Vu+ Duo 1.7.1 Server Tuner
I have to say that A867 works like a charm in my Vu+Duo with 1.7.1: never had a problem.
But I know that it works randomly, maybe I'm just lucky.
I'm sure that with 1.7.2 everyone will have the chance to use A867 without any sort of problem.
Hi,
I installed 1.7.1 and i cant even find the usb tuner menu.
i went everywhere, blue key , blue key pressed for longer, green key etc.
Where is it?
With 1.7.2, A867 works correctly and better :)
Hi,
Where is it?
After kernel changes we have adopted a new image structure and the old Tuner Menu is discontinued and unnecessary.
Drivers for USB DVB devices are included directly on the image.
It will be a double post but i still have the same problem...
When i press build server for tuner , it says that the server is built it creats the directory /media/hdd/tuner but there is nothing under \tuner....
I did not try but can this be a problem...I have USB disk attached to my DUO ; do you think that there might be a conflict writing the files when building the tuner server files ? (i do not think so but....)
Am i doing something wrong ? Anyone got an idea ?
Check the name of all your bouquets. No special characters including ( ).
One default bouquet that you may have is "favourites (TV)".
Make sure you remove "(" and ")".
