Black Hole Vu+ Duo 1.7.3 (Skin Tribute)
I can't install this image.
I've put it on a USB stick and updated the reciver but after rebooting nothing happens, the display say's ''starting'' and then nothing more happens.
What's the problem??
Did you upgrade the boot loader?
Hi There
I have installed Black Hole Vu+ Duo 1.7.3 and must say this is a great image I have found it very stable, the only problem im having is that I am unable to map the hard drive and USB drive from the vu to my pc useing win 7.
Could someone help with this, please go easy as im a newbi
Cheers
Fermec
This image is great and even better once I got hd glass 1.6 installed changes menu layouts so far no issues with image thanks to everyone who put this image together
I have a new issue with the file system going read only, this is happening 3-5 times a day and is cleared with a re-boot/hard reset. Anything that writes to a file (Like setting a timer) then causes a green screen. It is not a full RAM as I have a swapfile and the RAM usage seldom goes above 85% now. It seems to happen at random times and I've not been able to identify any process that causes this.
OK, restored a week old backup and all is OK again - something must have got corrupted.
hi. I have just flashed blackhole image 1.7.3, but my subcription card does not work. can someone please help me ?
Saluto tutti, e complimenti per l'IMG. Ho un problema con il DTT dual tuner usb NOVA T500, mi configura i tuner C e D (attivi) ma non aggancia nessun canale con la ricerca manuale, le impostazioni tuner sono corrette DVB T Europa ecc. Premetto che con la cinesina (af9015) va tutto OK....
grazie 1000
saluto sandro76
grazie 1000
saluto sandro76
Please use English in this section of the board.
