Black Hole Vu+ Duo 1.7.3 (Skin Tribute)
The skin coding is not coding for LCD
I do not know why it is different with you.
LCD coding is located in a separate coding and have nothing
with the skin coding and skin in use.
If you like to have different LCD coding you have to put this LCD coding in to image.
Tnx
I do not know but putting the skin there is this view, I do not know what else to think...
For file skin_user.xml I am writing here http://www.vuplus-community.net/boa...stallato-la-1-7-3-mi-succede.6177/#post-50322
Looks good so far. PQ on the HD channels looks better than on BH1.7.2, maybe just my eyes :)
One thing I have noticed though, on the Blue-Yellow info screen, all the values are zero, Flash in use, RAM etc, the HDD temp is N/A - is that normal or could I have a problem or a bad flash or something?
(/etc/enigma2/skin_user.xml)
dear help me how add this value
Memory full, do "Hard reset" in menu -> shutdownmenu.
I had tried pulling the power and it was the same, Hard Reset gives a Green Screen and GUI restart. I've even tried deleting all CrossEPG data from the USB to reduce the amount of memory needed and it's still the same.
Does this image use more memory than BH1.7.2, never had overfull memory in that and it had more plugins, more Picons and an extra EPG provider setup.
hi, thank for this very fast image, but I can't find and use Video enhancement plugin even if it's installed.. plz help
Green screen is because memory or flash is full, check settings of for example Crossepg so its not mapped to flash.
Ive had this problem on all images if i´m not careful with settings, swap and so on.
Great image, great skin, great job!
and, of course, great decoder.
Thanks to all who make this possible. My admiration and respect.
hi i have vu plus duo box with blackhole image 1.7.3.. my question is i have subcription card but not working for my box.. i just put the card in the vu plus slot.. but not working.. do i need to do anythingelse for that.... please help me...
No make same multiple posts please.
