We know if the Gradiend HD will be converted? i speak for the old Gradiend.. I just can use that all the new skins in double ok show the ecm infos and the rest infos in a new top bar....
Hi guys Iv intalled the multi quick button plugin to make channel buttons on remote zap up and zap down channels but since I cant jump dimensions even when I un installed the multiquick plugin. when I press red it just asks if I want to record instead?
Thanks again!
I have a problem. When I install multiquick button, I can´t select Parallel Universes with the red button. I assigned "Subservice Selection" to red button, but do it nothing.
Thanks again!
Thanks for skins matrix!
Im having a little trouble with the 2x ok osd epg info
It appears for 1 second and goes black like it is been over written by the now and next but appearing as black is there a way to to disable now and next info from been downloaded from the transponder??
I think you cannot disable now and next info from been downloaded from the transponder??
You probably using SKY UK EPG ?
Try to download EPG for SKY UK with CrossEPG
The problem is that SKY UK EPG does not use the same EPG text format from the transponder
as SKY ITA, Gemini ,C+ Nederlands etc.
Otherwise I'll have to make another version specifically for SKY UK EPG transponder
But first try to download EPG for SKY UK with CrossEPG
Tell me if it goes or not.
Thanks! Haven't still downloaded it, but can you tell me if the "Stream" button on the 'playing now' channel is back in the web-interface? It's the only thing I didn't like in the latest updates (openwebif?).
