Black Hole Vu+ Duo 1.7.4 Parallel Universes
I do not understand what you mean
He is asking, how do you make your nova card work.
Just putting the card into the box, will not make it work, you need to do other things (that are not allowed to be talked about on this board).
That thing (that we can not talk about) is where your problem is.
Use google.
3G Modem Manager doesn't work.
I tried with 3 different dongles, all of them are recognized, I configured the correct APN but when i try to connect I get the message:
"Occur error during connection...please check your settings"
(settings are correct!)
Sorry
I want to clarify to angelofsky1980
I've made this supposition.... the problem is not related to BH image or box.
The only relevant test is with the card and a CI CAM. Other tests are not useful and violates the Board rules and generates disciplinary actions.
Wil the plugin uitzendinggemist from pli image work in this image? i think no.
My question is: is it posible to make a plugin like : enigma2-plugin-extensions-et-openug_1.1-r0_mipsel for this image?
or is it imposible to do?
thanks for any answer.
I think you cannot disable now and next info from been downloaded from the transponder??
You probably using SKY UK EPG ?
Try to download EPG for SKY UK with CrossEPG
The problem is that SKY UK EPG does not use the same EPG text format from the transponder
as SKY ITA, Gemini ,C+ Nederlands etc.
Otherwise I'll have to make another version specifically for SKY UK EPG transponder
But first try to download EPG for SKY UK with CrossEPG
Tell me if it goes or not.
No joy Im afraid matrix from crossepg
But your last 2x ok = epg info skin worked fine on all providers
Thanks for your work!!
I think this is a question for the plugin author .
Plugin works only in the PLI-based images.
