JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Just get it now so Many Thanks to BH Team.
hello.
In first thank you for your exellent work.
I have a problem personally: when I installed new image BH 1.76
my VU+DUO rest blocked on "starting…" after the reboot.
I installed several times this image but without result.
while reinstalling the old image 1.75 it goes.
I even reinstalled the last always similar driver.
Somebody could give me an explanation.
Thank you in advance
hello.
Does your box work ok with 1.7.5 and the new drivers after a reboot ?
Every time I try to use BH Personal Back-Up my Vu+Duo crashes part of the way through. I haven't experienced this problem in previous images...any ideas?
This indeed a strange experience,,,try not to restore all items,,,for example restore with out the plug-in!
And attache a copy of the crash log!
Good image
thank's
Thanks to BH Team for your exellent work.
hello.
Have same problem....
sounds like you have a clone version of the duo.
Best contact your seller
Thanks Black Hole Team
hello.
you must install ''bootloader'' first
thank you with all for your answers.
Afflicted for the delay with my answer.
The problem remains the same one: I reinstalled the bootloader then the new image and with
starting I have the same message.
Is there a more reliable procedure to install the bootloader. in this case somebody
could show me this step.
thank you with all
Great skin, thanks for everything
thank you with all
How old is your Duo ?
Are you sure it is a Genuine Vu+ Duo and not a Clone ?
thank you with all
If the BH 1.7.5 image works, you don't need to upgrade the bootloader.
Maybe your 1.7.6 image is corrupted.
You can try to download it again and reinstall it.
Any news about ReDi PC100 device? Still not work. Have to wait the 1.7.7 or to return in previous ?
hello to all
I actually changed the file image while using
an image coming from another site. But did not change anything.
It should be noted that according to this forum some even the majority installed successfully this image.
Thus it would not be corrupted.
In addition my DUO has been very recent I bought it for approximately two months.
Thank you with all
hello to all
Thank you with all
Are you sure it's a Genuine Vu+ Duo and not a Clone ?
from libya free
