Black Hole Vu+ Duo 1.7.6
Hi since the latest blackhole 1.76 image , icant use the pause, forward, fast forward buttons (3,6,9) on my Nstreamplayer plugin (nvod) someone any idea?
Regards,
Alex
Strage ... But it's a plugin problem I think
Sent from my iPad using Tapatalk
Regards,
Alex
yes...i have the same problem with other plugins that use stream, the pause, forward etc don´t work... only with this last image 1.7.6... 1.7.5 works fine stream plugins.
thanks in advance.
regardsss...
Yep same here I was redownloading media player plugins thinking it was something to do with that hours and hours of pricking around its not the media players putlocker 1channel won't pause step forwar or back same with other plugins like that still scratching me head!
Just another thing the restore EPG back up stopped working as well, was fine on 1.7.5,
and yes my paths are spot on could this be a bug or Iam jumping the gun?
Just made a quick test (Hard reset, BH 1.7.6, duo),,,and made EPG restore,,,its working fine!
Check you EPG setup!
I will try that later wife watching soaps on the box Iam not aloud touch it for now (the vu+ that is)
Going back to the other thing about pausing step forward and back on the media type plugins that not working, I noticed that play /pause/ forward/ back buttons are normaly coloured red/green/ yellow/ blue they are all Gray in colour is that to say these functions are not available any more check it out,
The fictions only work for recordings on hard drives.
OK Fine!
And for the other Q?,,,I do no know> do not use TV stream plug-ins!
RgdZ
a911
Anyone using the Redi DVB-T has installed it ? Do they include the driver or should stay in 1.7.4 ?
Thank you
OK Fine!
RgdZ
a911
Don't use the the tv sream plunging! Are you kidding me the 1channel us the best ever plugins Iam watching tv shows that haven't aired yet movies that are not on sky yet it's brilliant thinking of cancelling me subscription!
I mean, personally I do not use any stream TV plug,,,my kids & the wife do,,:D ,,but not on my Duo!
I will Try ......
I have bad lock with OLD BH 1.7.5 many ( Fluctuation in signal ) Especially with high-definition channels .
note: you have any idea !!
Thanks
I will Try ......
Thanks
The fluctuation in signals have nothing to do with the image!
The frequencies and its correction factors,,is the cause,,,try a ready made settings and check!
I was loving 1.7.6 but I had to go back to 1.7.5 to use the play pause step forward & back on the likes of plugins like 1channel
Hopefully it can be resolved with a patch or on the next update.
thanks to the BH team for all their hard work
I'm having audio dropouts with some downloaded youtube music videos , i have had these for ages and went to play some back last night to find the problem.
I went to view the video on youtube same probelm, went back to an older image and works fine again, is there anything i can do to fix?
Thanks.
