Black Hole Vu+ Duo 1.7.7 HbbTv
******* does not work with this image, any news when this is going to be fixed or updated to work with the *******.
Many thanks
ALfie
HI, thanks for your great work.
a question, in the last version exist a problem with some dvb usb sticks (like WinTV Ministick) that recognize as DVS tuner.
in this version is this fixed?
thanks a lot again
-DAVIZINHO-
Great jobs guys!!!
A question only.
If I'm in HbbTv, how can I adjust the volume level?
Thanks!!!
Thanks bh team.
Only one problem does not work wintv ministick from version 1.7.4.
Recognized as satellite
Enviado desde mi GT-I9001 usando Tapatalk 2
I just installed the 1.7.7, HbbTV is working and all. But this image has even after a hard reset a terrible lag. I have, as always, the USB formatted and partitioned so everythings running over the USB including swap in Avalon universe.
Is there someway to speed up the image , am I doing something wrong. I had similar problems with 1.7.6 and posted about the problem, 1.7.4 was ok but this lag problem increases with the upgrades.
thanks for the new image
still testing it
only found a problem when i use hbbtv and after use i want to use it again i need to restart my box (vu+duo)first otherwhise it wont work anymore
maybe someboddy knows what to do??
and how can i change the volume in hbbtv??
still testing it
To exit HbbTv plugin you should press EXIT button on your RC...
