Black Hole Vu+ Duo 1.7.7 HbbTv
same problem ...."exit" button doesn't work. the only way is to reboot manually the box
Also had the same problem, also the starting of HbbTv takes a while, can take up to 1 minute.
General as already posted the image has a lag. Twice already during reboot the Receiver stays in "Starting", channel is visible but remote doesn't work so you have to hard reboot again.
i did flash img again and again have the same problem if i use hbbtv brouwser not started
after reset of the box its ok again
but after i did use hbbtv again it needs a reboot because get the same message brouwser not started
Thanks a lot guys for another great image!!!!
Quick question regarding multiquick button. I followed previous posts about editing keymap.xml and got it working fine with 1.7.6. Is there any further modifications required for 1.7.7?
Cheers
great image thank you,
but unfortunately I have to go back to BH 1.7.5! the problem with 1channel has not been fixed the issue with pause step forward & back wont work same as the BH 1.7.6 image it cant be a plugin issue because it works perfect on earlier versions of the image
Do you test clean image
or image which you filled to the point that he no longer works as it should work.
HbbTV works very well as the whole image.
Test first clean image without big additions.
WHY NO ONE LISTENS TO THIS GUYS PROBLEM?
I also have the same problem since 1.76 version,
all other images , even OE2.0 images have no problem.
only blackhole the last 2 versions :-( , i m really a fan of blackhole, i share my backup with people who has no idea to set up an image, except to install a backup.
SO PLEASE BLACKHOLE TEAM, hear our criying , and fix this issue in the next image..............
(the plugin where forward/pause step forward etc.. doesnt work is NvodStream plugin.
Thanx, and sorry for shouting, bu other wise no one hears us :-(
