Black Hole Vu+ Duo 1.7.8 Lite (No HbbTv)
Great image, thank you BH Team I think you peaked!
I honestly cant see how you can improve on this work
Well done everyone conserned
Thank you all again!
Instant green screen crash on MyTube when trying to play a video. Tested on a clean installation, too. Also, it's been quite a while the Standard Feeds do not work, may be they should be removed. It's cute, but how many times can one see Charlie bit my finger? :p
edit: Ok, just saw the above comment, thanks Matrix10.
There's a small GUI problem in the plug-in reorder page: most of the times the scroll bar on the right, covers the order numbers.
Great Job... usb TDT Volar Black HD (A850) not detected in this image?...
Strange. I tested a similar device who uses the same driver and all works correctly.
Installed BH 1.7.8 and later BH 1.7.8 Light and not detected usb TDT... be if it is confirmed by some user that should have this usb TDT... i have returned to the image BH 1.7.7 and OK...
sorry for my English...
Specify WHAT USB DVB-T device ....
Hi
I press the red button, but it doesn't open the red pannel.....do you know why?
Regards
1-By pressing the RED button LONG , you will get BH Universes!
2-By pressing the RED button Short m you will get Hbbtv functions ( Not w/BH 1.7.8 light No Hbbtv).
3-By pressing the RED , while you are @BH Green Panel, you will get Panel setup!
Great.....I'm using the BH w/o Hbbtv and I pressed shortly the red button, so I didn't receive anything :)
I will try this evening with the long press.
Thanks
Thanks
You did not receive anything because on that channel have not hbbtv.
Go to the channel which have HBBTV and You will get it when press one time short red button.
