Black Hole Vu+ Duo 1.7.8 Lite (No HbbTv)
1-By pressing the RED button LONG , you will get BH Universes!
2-By pressing the RED button Short m you will get Hbbtv functions ( Not w/BH 1.7.8 light No Hbbtv).
3-By pressing the RED , while you are @BH Green Panel, you will get Panel setup!
I installed the BH 1.7.8 (full), I formated my usb and change the mount point (/universe), when I press the red button it does nothing (how long do you press the red button?)
Is this another way to reach the universe?
thanks
thanks
As long as the Universes shall show up...;)!
ok, it works......the problem was I didn't use the original remote (but a Logitech Armony universal remote).
Now I'm on Avalon.....if I reboot the decoder, it will automatically enter in Avalon or not?
Regards
Regards
If you don't set a PIN for the Avalon universe and you keep connected the USB stick with Universes ... the box boots into last universe you use
Problem in satellite Yahsat 52.5 Unfortunately, all Receivers vu+ Enigma 2, the satellite Yahsat 52.5, GEM HD channels there is a problem. All these channels appear to be fragmented and the sound does not match the image. If this is a problem common to other receivers, such StarSat and Iclass there. This problem exists in all images OE 1.6 and OE 2.0. Please check this thread.
