Black Hole Vu+ Duo 1.7.9
i have problem. i uppgrade from b.h 1.7.8 to b.h 1.7.9 for 3 days ago. the box has hanged on starting 3 times, no crash, when i restart with telnet, nothing happen, i restart the box manually, but still hang on starting, the only solution is reflashing the box,. the last 3 days i reflashed the box 3 times. i had the box more then 2 years allways b.h image , had never had such problem before. Any one expereincing same problem.any solution is appreciated.thanks in advance,
When you reboot your box, post here at least a "dmesg" output.
thank ypu for your reply.may i ask,( dmseg output) is it the same as crash log ? because the box doesnt crash, i do not get crash log. for example today i tried to download the plugin 1 channel fron b.h addon, after installation, enigma must restart, but it shut down, the vudo on front screen, but the box doesnot respond to remote controll, nothing happen , when restarting manually, box hang on starting ! any suggesstions is appreciated.
Connect to your box via telnet and then issue this command:
dmesg > /tmp/dmesg.txt
Retreive via FTP the /tmp/dmesg.txt file and upload here.
Hallo,
Ein Tolles Image. danke an die Macher.
Ich habe EPG problem. Mir BH 1.78 läuft das egp einwandfrei. Aber mit 1.79 habe ich kein EPG une in der Kanalliste kein Sendungs-Fortschritt, obwohl das im System/Anpassen eingeschaltet ist.
Was muß ich machen damit wieder läuft.
Poste dein Anliegen bitte im deutschen Bereich.
Da bekommst du auch eine Antwort , denn hier ist fast niemand der deutsch
Spricht
admin i m new and this is my first post today i have install image 1.7.9 my vu+duo i face problem i m changing skin but show massage this skin not support
pls help
i need this one
Army curveHD VU BH1.6x v1.0
pls help
i need this one
This skin is made to old version image; he no work becouse in last version images was made big changed and thsi is reason why no work.
Try other skin made by Army and Matrix10 made to version 1.7.x .........
hi guys,
im new i just bought VU+ Duo i download image bootloader i have original box , could you help me to install Black-hole and bootloader . and lastly ***** plugin im dm800 user
hi guys,
You have to read our board rules before to post again!
User banned for a week!
