Black Hole Vu+ Duo 1.7.9
Thanks, great work!
I 'm almost too embarrassed to ask: On the remote control, the "Channel + / -" buttons don't actually switch channels directly, but display the channel list. Any way to change it back to the 'primitive' 'channel up/down' behaviour? (...and I don't understand what the ZAP mode option does?)
Hi, and sorry if this has been asked before. On my box that I recieved eterday, it has the following information:
Dream Elite Black Hole
Enigma 20-01-29 master
Image: Release 1.0.0 2010-06-05
Should I upgrade? Will this screw up any other plugins that are already installed, e.g. *****, ****, ******?
TIA
Stuart
TIA
Stuart
You are banned for one week.
During this time you can upgrade your box safely.
Next time you make a similar post with emus, your ban will be extended to LIFE.
Thanks, great work!
I also I have always this problem .... I fix and changing the file keymap.xml, which was usr/share/enigma2
I leave the file already edited
<?xml version="1.0"?>
-<keymap> -<map context="ListboxActions"> -<device name="keyboard"> <key flags="mr" mapto="up" id="a"/> <key flags="mr" mapto="down" id="b"/> </device> <key flags="mr" mapto="moveUp" id="KEY_UP"/> <key flags="mr" mapto="moveDown" id="KEY_DOWN"/> <key flags="mr" mapto="moveTop" id="KEY_HOME"/> <key flags="mr" mapto="moveEnd" id="KEY_END"/> <key flags="mr" mapto="pageUp" id="KEY_PAGEUP"/> <key flags="mr" mapto="pageDown" id="KEY_PAGEDOWN"/> <key flags="mr" mapto="pageUp" id="KEY_PREVIOUS"/> <key flags="mr" mapto="pageDown" id="KEY_NEXT"/> <key flags="mr" mapto="pageUp" id="KEY_CHANNELUP"/> <key flags="mr" mapto="pageDown" id="KEY_CHANNELDOWN"/> <key flags="mr" mapto="pageUp" id="KEY_LEFT"/> <key flags="mr" mapto="pageDown" id="KEY_RIGHT"/> <key flags="mr" mapto="moveUp" id="1"/> <key flags="mr" mapto="moveDown" id="2"/> </map>
Does anybody know if the permanent time shift works with BH 1.7.9
can't find an answer anywhere. I'm new to the vu+ box
Thanks all
I installed this image onto two boxes last night. What an absolute dream to do! The developer(s) who worked on this release deserve a very hearty slap on the back. Brilliant work fellas! :dance:
I have installed this image today on my Vu+ Duo,looking very nice,but have some issues with zapping.When i watch channel for lets say 1/2 hour and want to go to next channel,stb goes to reboot,very strange.
is it reboot or crash with 'amazing' :eek: green screen? If the second one just post your crash log here, if first one - just add a bit more details about your configuration (swap file, hdd, usb, epg, etc...)
thanksssssssssssssss very nice share
Has anyone got the old keymap please I replaced it with the supplied here and iam missing functions on my Duo now like audio so on please!
