Black Hole Vu+ Duo 2.0.2 - Meoboot Revenge
This is not a flash problem but a ram problem related to epg.
Install a fresh image and create a 256M swap before of all and before install settings and download epg.
thanks Shiro for your help so far.
Iam now going to do a reflash from scratch.
so when i go to set up swao file set it to 256 MB then what map the EPG for that partion and then install my addons or have i got it wrong just want to know that iam doing it right before i start
thank you.
I do not know exactly what is the reason for the lack of RAM.
But the fact is that you have in log information about the lack of RAM.
We should not forget that image two years ago and now not have the same
requirements. Same goes for some plugins, but especially for the EPG
Now if it is or is not the reason of course I do not know.
Basically I wanted to say
that these boxes are doing, still really good
provided that you leave space for stable operation.
found this lhttp://www.vuplus-community.net/board/threads/how-to-setup-latest-blackhole-epg.8407/ink here
whats does this mean this line below and do i do it, telnet?=
If U have Vu+ Duo , install the script Free-Ram and Swap enforcer , in order not to over load the STB's RAM!
I have no experience with SWAP.
I installed once for the test ,
But he was not used
Frankly I'm not thrilled if I have to add SWAP
in the image.So I never use SWAP.
Basically I use BH image in its base form.
So I can detect the real problems and bugs.
What is not possible if I put something that could be causing the problem.
My box works without SWAP days without problems.
But I use very few EPG and plugins.
So always advise
test with a clear image even a couple of days
to find out what causes the problem,
before and after you add something.
But he was not used
So always advise
i have already started i have set rytec uk for swap file have done a clean reflash dont use meny addons maybe 3 at beat will report back later thanks.
I did say my neighour has the same problem with his duo on BH latest not just me.
In order to keep good Flash memory , I do the following:-
1- Install BH Image @Flash, keep it clean no settings, no Tuners,,,no nothing,,,,, just pure!
2- Remove all plug-in, that not used by me!
3- Mounts my HDD and USB!
4- Install Meoboot on USB ( I use only 1 partition, NO Bh Universes this time...;))
5- Install BH on meoboot....loaded with my favorite plug-ins ( more than 10) and settings,,,etc!
6- Test few images, for the fun of it,,,then go back to my BH..:inlove:!
7- Using Epg Cross,,,saving data on my HDD!
8- No Auto epg-refresh!
9- Use swap file 32M!
10- Randomly clean my RAM with Free-Ram script ( made by my friend P2P)!
Never had a crash with BH 2.02 since its published!
RgdZ
a911
hello ,i would like to ask your help in a problem i have with meoboot.
Rihgt now solo2 says that meoboot runs from vu+.i have mounted a usb for flash memory and iam in avalon universe. I also have mounted and formated a sedcond usb in ext4 for meoboot use.
when i start meoboot i dont see the usb to install it. I see only two options:
a) /etc
b) /var/lib/opkg
Can you please tell me what should i do?
a) /etc
b) /var/lib/opkg
Into Devices Manager both USB sticks are correctly mounted?
yes they are, with the first one i go from avalon to normal with no problems. the second i see it also mounted and mapped as media usb.
i will do that.
but when i start the solo2 it says that meoboot runs from vu+. that means its in solos flash memory or is in the usb universe?
shall i delete meoboot too,and reinstall it?
i will do that.
I admit my inexperience with MeoBoot .... but I suggest to reflash your box and reinstall MeoBoot in another USB stick.
Other members of this Board hope can help you in a detailed manner without reflash.
