Black Hole Vu+ Duo 2.0.2 - Meoboot Revenge
After the latest recommended update i still got 9 new updates over and over again, reboot and still the same message!
Is this a bug?
Prima di installare questa immagine devi aggiornare il boot loader.
Nella discussioni di cui al links precedenti, puoi trovare sia il files che le guide per gli aggiornamenti.
Purtroppo per me...penso che ci sia qualche cosa che non va....neanche BOOT LOADER parte
Rimossa la chiavetta USB al riavvio si blocca e non posso fare niente...almeno niente che io sappia
Thanks a lot for the Rev. A update. Is it possible to maintain the Black Hole Speed Up settings for future online updates? Currently, they are lost after the update.
Sicuro di avere un apparecchio originale?
Non sarà mica un clone?
Im having problems installing plugins from the main menu.After selecting plugin to install and pressing yellow button for process my selcted plugin shows up together with stb update.Stb update installs but not the selected plugin.After restart its the same thing over again.This is the same booth with flash image and meoboot image.
Wrong procedure.
To install plugins on Bh image you have to go to maine menu -> addons and use Bh addons server or Bh plugin feed
Io sono italiano...poco esperto... compro in Italia e non so molto altro di quello che ho scritto.
Scusami ancora non pensavo fosse una cosa così complicata :-(
Please don't post in other languages than English in this section!
We have an entire section for Italian support.
Thanks
Hi, i'm having a little trouble if anyone can help?
I'm currently on BH version 1.7.4, Ive updated boot loader lots of times and updated the BH image from this thread, but it's still getting stuck on starting?
My tv picks up a signal as if the box was starting up.
I've read through lots of threads but I'm still having trouble.
My box is a vu duo 3 /4 years old thanks
Does it get stuck every time, so it won't boot at all, or only sometimes? If the latter and you're using a USB stick, make sure it is NOT ext2 or ext4 formatted. Reformat it to FAT32 filesystem.
USB was originally in fat so i formatted it to fat32, I did however get it free, so I bought a new 32g usb from curry's and formatted that to fat32 and still the same.
The box has just come back from the shop as the internal hard drive broke so a knew one was installed.
I'm not an expert but I'm not totally ignorant so I'm hoping I can get this sorted with some of your expertise :)
I'm unsure whether the new hard drive was initialized, so i shall re flash BH 1.7.4 and make sure all is good and running cheers.
reformat the USB again (erase format) and extract the Image.zip file directly to the USB!
Read here>>http://www.vuplus-community.net/board/threads/how-to-update-vu-images.11819/
