Black Hole Vu+ Duo 2.0.2 - Meoboot Revenge
Thanks and keep up the wonderful work you are doing.
Questions:
Is there a plan for a kernel update as per openpli?
Or kernel will remain as it is?
I know there is a lot backported code from newer kernel but i thought to ask anyway ;p
I have been using BH images for long time with no problems with an emu, but now i have an original conax cam inserted to my vu+ du0 and have orig subscription to Canaldigital denmark
and i not using emu anymore. after that the only problem i have is with some of the HD channels i cant even see BBC HD Because it is lagging a lot i seems like i have a bad signal, but if i use another image lige openpli or openvix no problem at all every HD channel working perfectly, but not with BH and original CAM and SUB. samme problem occurs with VTI image seems like at driver problem. but can only say that i miss to use BH image like in the old days and HDMI Cec is working perfectly with BH image.
i could not even install the new image in usb flash memory - after instaling it in flash
meoboot sees all images including bh 2.0.1 - but doesnot see the new bh 2.0.2
is there something diffrent from old meoboot
Meoboot is different, but
For users no difference.
I think .That must be some other problem.
I have not test with DUO but with Solo2 and Ultimo.
Maybe someone else could test with Duo
The new Meoboot works perfect with DUO!
Install BH 2.o2 on flash,,,format your USB with ext4!
Install meoboot on the USB while you are at flash, then upload BH 2.o2 or any other oe2 on it,,,,etc!
Ciao a tutti...
Ho un Vu+Duo - DVB-S2 HD TWIN PVR - Non riesco ad aggiornarlo alla nuova versione 2.0.2
Qualcuno mi aiuta/ mi spiega perché non ci riesco????
GRAZIE
Ciao a tutti...
GRAZIE
Dovresti fornire maggiori informazini per ricevere un aiuto.
Cosa intendi per non riesco ad aggiornarlo?
Che immagine è installata attualmente?
Hai aggiornato il boot loader? Vu+ DUO Boot Loader Updgrade
Hai seguito la corretta procedura per l'aggiornamento? How to update Vu+ images
Hi there. I had no difficulty using image BH2.0.2 in flash and in Meoboot. (VU DUO). You have to use image exactly as you use it in flash, no name change . I tried to rename it, avoiding "usb.zip" at the end, but it was not accepted in Meoboot. When I used it, with the "usb.zip" at the end of name, it was accepted right away.
Personally I find it a very well balanced image, thanks BH team for a very nice image.
Ledra
Grazie per avermi risposto.
Sono nuovo del forum ma anche e soprattutto del Vu+Duo. Non so che immagine sia istallata... Cito quello che leggo nelle informazioni:
Black Hole Enigma Image Experimental 2011-03-22
E penso che sia anche la data di acquisto...io lo tengo da circa un mese.
Non ho aggiornato il boot loader, non sapevo di doveerlo fare.
Ho provato l'aggiornamento in flash da chiavetta usb,e come dicevo si blocca.
Scusate "l'ignoranza" in materia ma ... sbagliando si impara :-) spero.
For those who have problems with the network
after image update (BH 2.0.2 A).
Switch to DHCP first in network Configuration to reset network
reboot.
After that, you can config your network if you like to change.
DNS name server is automatically configured
(though you can not see in Network panel)
you can also config manually.
Scusate "l'ignoranza" in materia ma ... sbagliando si impara :) spero.
Prima di installare questa immagine devi aggiornare il boot loader.
Nella discussioni di cui al links precedenti, puoi trovare sia il files che le guide per gli aggiornamenti.
