Black Hole Vu+ Duo 2.0.3 Hyperspace
Is there a problem with subtitle player? When I select the title and press OK the box stucks and I can't do anything but switch it off from the backside button.
Yesterday I tested it and it worked.
I tried to uninstall the plugin and install it again, but the problem still remains.
hello the bootloader (3.0_cfe) is one for this image ?
If you need to update your bootloader, look into "Vu+Duo Bootloader update" in the Vu+ General section of this Board.
If you have installed an image earlier than 1.6.6 (from 1.7.x or earlier) you don't update anymore your box: it's ready for new images.
thx for a Another great image...:yahoo:
a reflection could be only me but...tried a couple of times to do a online update from 2.0.2D to this latest 2.0.3. (yes been lazy and skipped 2.0.2E)
but no go..downloads allright and when i´m being asked to restart stb it hangs....tried a few times and still the same..downloaded here on sight and loaded it by usb and all is ok...
regards
kchris
regards
kchris
You cannot do an online update from 2.0.2x to 2.0.3 because of new kernel used. Fresh install is required.
Hi Guys, I hope someone is able to help, since upgrading to this image the 1Channel plugin has been giving me the GSOD,
I have attached the latest crash log file in the hope someone can help me sort this out.
cheers
cheers
I saw something inside your file and thats a reason, why I can't help you. Read Forum Rules, please! Uninstal, you now what, and try again.
Could you be more specific - maybe in PM? I looked in his crashlog and found nothing that would break the rules. Maybe I do not know of something that's not allowed apart of the "usual stuff" and would like to know.
cheers
I think the reason for crash is, you have a little free space in flash.
Apologies if there is something in my crash log - Please feel free to remove the log file
As far as i can make out (and I'm far from being an expert) there seems to be some sort of conflict between 2 plugins I am using, maybe dependencies???
ie when airplayer is working and showing up as an option on my iphone, then 1channel gives me GSOD and when 1channel is functioning airplayer is not visible to my iphone. Obviously I'm not trying to use both at the same time lol
Try to free some flash uninstalling what you don't need by BH Speed Up (plugins too) and by this http://www.vuplus-community.net/boa...-image-flash-memory-removing-languages.12595/ if you understand, how to do it. Don't worry for *.log. It was only an advice, how to spend your free time ;) .
