Black Hole Vu+ Duo 2.0.3 Hyperspace
Frinds... the last 203 is pretty good... but only one stupid problem is present-- since 2xx the my TUBE fast forward and rewind is NOT working with the usuall 3 6 9 buttoms-- also tryed in UNO, DUO, not in function.. not in ULTIMO too.. i wrote this in somewhere, but no usefull feedback--
Sorry if i did some anger here, but this is one of the thing why i hold the 179 for a looong time, there worked- works!!
Thx
ps: with utube plus plugin -- this function works, i dont like the plugin(sorry to author)..
hi, can someone take a look at this crash log file, my duo keeps crashing when i press the record button, it only seem to crash when i use other skins, if i use the default skin, thing seem ok, the skins i am using i have used before, i am using bh 2.0.3
It's permanent timeshift causing the crash. I experienced the same. Look here for a solution: http://www.vuplus-community.net/board/posts/92248/like
thanks alot, there are two versions of permanent timeshift on the black hole server
option one green/yellow/addons download manager/black hole addons pluggins then permanent timeshift 1.0.0 final (black hole e2)
option two green/yellow/addons download manager/black hole feeds plugins then permanenttimeshift
i was using option two before, this was causing me green screen, i deleted this version, then i went for option one, everything seem fine now, no green screen when i press the record button
not sure what the difference is between these two permanent timeshift,
Can I use my old images (BH 2.0.2c, OpenPli 3.0, Vti 5.1) that I have in Meoboot? or will it be "drivers issues"?
Thank you for your greats jobs, BH is my favorite, just one question is ******* compatible with
Black Hole Vu+ Duo 2.0.3.
regards
One question, are personal settings from version 2.0.2 compatible with version 2.0.3.?
I mean, if i use only settings, terestial
Thanks for answer
