Black Hole Vu+ Duo 2.0.9.1
OK thank you, and sorry I meant I had 2.0.9.0, just got the newer one was going to play.
Thank you for that, did that last night, will check to see if its worked later today, much much appreciated for the advice, shame there is not a full image complete and sorted for people like me with limited knowledge, and new ish to this.
How about you reflash? If you need help, please let us know. I believe many users will help you. Some of them are realy knowledgeable.
I have this problem:
I plug the usb, the box starts reading, than it tells me to reboot. After unplugged usb key, I switch back on the box and it won't boot up... the LCD stays black e nothing happens, only the red dot on the display is on. This is happening only with 2.09.x release, the 2.08 is fine... can you tell why?
hi all, could someone help me out..
I tried to flash for the first time, I had openpli and went to vix but I could see a thing on my screen.
So now I flashed the bootloader for BH and after that flashed this image, now I see on the display 'select video por' and nothing on my tv again.
Black Hole 2.0.9.1​
Whats new:​
  • [blindscan] support blindscan on vusolo2
  • [OpenWebIf] update
  • [hbbtv] update
  • fix ait dump w/ multi-section
  • [blindscan] support bcm7346 tunner.
  • [Customize] add preferred tuner option.
  • [AV Settings] add PCM Multichannel entry.
  • [Frontend] fix set PLP ID for DVB API VERSION 5.9 or later
  • Update drivers 20140310
    - Fix PCM MultiChannel problem(solo2, duo2)
    - Fix vtuner PIP
    - Fix Dual tuner loop-through input from single tuner(duo2, ultimo)
  • Update drivers 20140306
    - Support blindscan(solo2, experimental)
    - Support both SCART & HDMI audio in passthrough mode.(uno, ultimo, solo2, duo2)
    - Fix no audio problem in some radio channels
    - Support PCM Multi Channel(solo2, duo2)
    - Fix timeshift problem
    - Fix loop through problem (duo2, single tuner)
    - Support dynamic contrast in PEP
    - Turn on PQ Enhancement by default
    - Add more PQ enhancement proc entries(solo2, duo2)
    - Fix vtuner problem when RestartGUI
    - Fix some CI modules recognition problem
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
The attach file is not for DUO !
hi all ,
first i would like to say you good job
I just install the new image of BH 2.0.9.1, after that I tryed to istall same IPK's that i seved before (***** INFO....) unfortunatly i can't due to problem compatibility. can sameone help me, IPK's that I saved works good on BH 2.07
or can samebody give me a link of cccaminfo ipk or tgz compatible with BH 2.0.9.1.
Many thanx
hi all ,
Many thanx
I can give you only a link to the forum rules.
Discussion about emu and files related not allowed
Next time I'll give BAN.
