Black Hole Vu+ Duo 2.0.9.1
Black Hole 2.0.9.1
Whats new:
  • [blindscan] support blindscan on vusolo2
  • [OpenWebIf] update
  • [hbbtv] update
  • fix ait dump w/ multi-section
  • [blindscan] support bcm7346 tunner.
  • [Customize] add preferred tuner option.
  • [AV Settings] add PCM Multichannel entry.
  • [Frontend] fix set PLP ID for DVB API VERSION 5.9 or later
  • Update drivers 20140310
    - Fix PCM MultiChannel problem(solo2, duo2)
    - Fix vtuner PIP
    - Fix Dual tuner loop-through input from single tuner(duo2, ultimo)
  • Update drivers 20140306
    - Support blindscan(solo2, experimental)
    - Support both SCART & HDMI audio in passthrough mode.(uno, ultimo, solo2, duo2)
    - Fix no audio problem in some radio channels
    - Support PCM Multi Channel(solo2, duo2)
    - Fix timeshift problem
    - Fix loop through problem (duo2, single tuner)
    - Support dynamic contrast in PEP
    - Turn on PQ Enhancement by default
    - Add more PQ enhancement proc entries(solo2, duo2)
    - Fix vtuner problem when RestartGUI
    - Fix some CI modules recognition problem
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Hi thank u
Hi, i have a problem with weather plugin provider, can't find my town, is possible to chage msn to yahoo weather.
Thanks
