Black Hole Vu+ Duo 2.1.0
Thanks team.
One minor bug with Teletext. Box and remote do not respond and needs to be restarted with power button.
Also what does the green button next to the clock mean.
Thanks team.
Yes that`s true.
It`s not a great problem but it is a problem.
Good
Black Hole 2.1.0​
  • New skin by Matrix MX X Line
  • New plugin Fast OpenEpg
  • Updated Crossepg to the latest 0.81 version
  • Updated OpenWebIf
Drivers update:
20140424
- Fix multichannel audio problem(solo2, duo2)
20140418
- Fix DVB-S2 Single(AVL6211) tuner problem(duo2, ultimo)
- Change nim_sockets of DVB-T2 tuner(duo2, needs a E2 update)
20140403
- Fix audio problem(duo2, solo2)
20140318
- Fix dual tuner lock problem(duo2, uno, ultimo)
- Fix PCM multichannel from standby(duo2, solo2)
20140316
- Fix DDP problem(duo2, solo2)
Bh OE:
  • [WLAN] Added recipe and patches for Realtek RTL8192DU driver (v4.0.0)
  • Added recipe for v1.0.9 e 1.0.18 LibUSB library
  • [dvb-apps-v5] updated to latest commit
  • [lcd4linux] update to 4.0-r4
  • [gstreamer] prevent accumulation of old cached buffers in input-selector.
  • [PCSC] added recipes for CCID PCSC driver to latest version compatible with Vu OE
  • [hbbtv] fix play state error on VOD
  • [hbbtv/youtubetv] update vod player.
  • [base-files] fix fstab
  • Use ntfs-3g for mounting ntfs filesystem.
  • Uupdate web-manual for vusolo2/vuduo2.
  • Fix duo2 flash size.
  • [Languages] updatelang: cs, el, es, fr, no, ru, sk, sv, uk.
  • [NimManager] fix hasNimType for DVB-T2
  • [keymap/rcinput] Adding key code for fastforward/rewind.
  • [VideoEnhancement] add entry vertical_dejagging, smooth
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Ok there is a workaround to get teletext working for those that need it.
telnet into your box and then type the command
opkg update
and press enter.
Then type the command
opkg --force-overwrite upgrade
and press enter again.
When it has finished, reboot your box and teletext will be working.
opkg update
and press enter.
wow...... thank you so much, it works perfect
