Black Hole Vu+ Duo 2.1.0
Does the size of the flash drive matter? because it seems that my device can not read the flash, I tried to download it again, it is just like there is nothing happening!
hello team
thx for the great img but i have a question to ask about cross epg
i use meoboot and did install new img in flash and on meoboot usb mounted it also everything is ok
but when i want to update epg via cross epg then it wont work
the only thing i see is the turning of the satellite disk but i am on the satellite 28,2 all readdy
1 i put cross epg on usb
2 update rytech epg
3 open tv providers than sky uk open (28.2)
4 download ... but than i see the disk is turning but i am all readdy in the satellite 28,2
in the older img,s i never have this problem
maybe someone can tell me more???
thx you for answering
greetzzz
Ok there is a workaround to get teletext working for those that need it.
telnet into your box and then type the command
opkg update
and press enter.
Then type the command
opkg --force-overwrite upgrade
and press enter again.
When it has finished, reboot your box and teletext will be working.
Many thanks Ev0 for very usful post, and thanks BH Team for nice image. Keep your
wonderful work guys.:thanks::thanks:
acer2
All is excellent except one thing: the characters are not well. The info bar does not decode correctly the letters, for example what is on now etc. Any solution for that?
Thank you for the great work!
I have upgraded to the this version and now I can only free to air channels!
I notice the var/etc folder has disappeared ? where shoul dthe ccam.cfg file be placed?
4) Discussions regarding, pedophilia, pornography, piracy (keys, emulators, card sharing,
softcams, serial, crack warez) and to any debate illegal under existing laws are not allowed.
Recall also that it is illegal to reproduce your subscription to any Sky decoder IC that
has not paid the royaltes to NDS Group plc.
has not paid the royaltes to NDS Group plc.:chair:
