Black Hole Vu+ Duo 2.1.1
After installing bh image through meoboot and installing plugins and CAM - ov my hard disk mapped began to fall out, after a reboot everything is working well for some time and then it fails again.
I tried to reinstall everything finishing, but after some time the problem reappeared.
When all works except the loading HDD in device manager I have an empty field.
Downloading movies is working OK, but when you update picon in hdglass harddisk seen.
Does anyone have a similar problem? Of course I bh 2.1.1
It could be me and so I installed it again and check each step. This is a skin HD Glass latest version. Skin works without problems, but when you download picon-users, icons ... and other supplements I mapped the HDD will disappear through the explorer, the selected HDD usb directory opens. I set up the default skin, but when everything is OK.
So the problem was clarified, but uncorrected.
My problem may somehow be associated with meoboot and the same image on the Flash and usb operation, whether ... I have the problem not meobootu without.
Hi everyone. Have recently flashed my VU+ Duo to this new image and everything seems to work fine for 10-12 hours. Then it will crash and get into and then continue to crash on startup putting it into an endless loop and never starting. The only way out of this seems to be to reflash and setup again. All I have installed is this image and the latest ***** plugin.
Uploaded a photo of the error as I cannot boot to get into the logs :(
You should know that here, emulators are not welcome.
Banned for 1 week
Which Skins are working together with 2.1.1? Addons server only says 2-3 pcs....can I use Skins that are for 2.0.x?
I had problem to mount external HDD with CIFS. NFS worked OK.
After hours of testing I downgrade back to BlackHole 2.1.0 (CIFS or NFS sharing are working without any problem).
I upgraded Black Hole version for my VU+ Duo to 2.1.1 today (I didn't use my Duo from March).
I've found two different things, compared to my last update:
- WiFi doesn't connect automatically. I shut off my Vu+ every night and when I turn on the Duo, it doesn't catch my wireless network, even if wireless network is set to "ON". I have to enter into wifi settings menu. Only after these two steps, the light on wifi usb key starts blinking and then Duo shows the IP;
- did anything about HDMI out changed in these months? I was able to use Duo through a HDMI splitter months ago, while now it just doesn't show images on screen. I've checked everything (cable, switch, ecc.) and it seems the DUO isn't anymore compatible with this switch.
As always, thanks a lot for you work on this amazing decoder!
Hello !
First thanks for your job :)
Second - i dont see YouTubeTV in menu at VU+ Duo (2.1.1)
I have this in Solo2 and Duo2 Blackhole 2.1.1 (i very like VU+ :P).
I must install this manually ?
Any link for pakets ? Manual ?
PiVi
Hello !
I have this in Solo2 and Duo2 Blackhole 2.1.1 (i very like VU+ :p).
PiVi
You should enable HBBTV from BH SpeedUp to have Youtube TV.
Ok first of all i should say that am very pleased with my VU+ purchase years ago :) thanks to you guys.
Secondly i would like to report that new kernel works wonders and box is more snappy and temps have fallen a lot now outshell is not so hot to the touch is like lukewarm and am very fascinated by the outcome.
Kudos guys for an excellent work and support all these years.I wouldn’t have made a better purchase decision! Am proud of my self thanks to you and VU+ have given my family a lot of hours of pure entertainment.
