Black Hole Vu+ Duo 2.1.5
Thanks from me also. Is this supposed to be more stable with more ram to stop crashing?
Regards,
Jules.
I'm still using an older version that works well for me.
I'm here to say thank you Blackhole for your efforts better team .
Hi Guys,
probably me but i'm downloading the file and unzipping it onto the USB like i usually do but not flashing the box,
Am i doing anything wrong? I'm sure it is,
Thanks,
David
Hi Guys,
Thanks,
David
Have you tried switching off at the back for a min` or more then restart with usb stick (with said file on) using front usb port.
I have another usb stick in the back (for crossEPG and other stuff) but I never have to take it out but if problem maybe if same
take it out. I`ve never had to disable my internal HD in all the time I`ve been reflashing my Duo
This image flies on my duo no swap no nothing needed, rock stable no reboots and image quality is amazing.
Dont know why some users were complaining about this 1080p fb updates. I didnt test the previous one though tbh :)
Thank you and kudos guys, this image is amazing.
What i would like to see next is a rolling release with net update capabilities.
Keep up the great work you been doing all these years for us for free.
