Black Hole Vu+ Duo 2.1.5
Hi Guys,
probably me but i'm downloading the file and unzipping it onto the USB like i usually do but not flashing the box,
Am i doing anything wrong? I'm sure it is,
Thanks,
David
Many USB stick model do not work. You have to try another model of usb stick I have many that is not recognized.... :)
Then it works again as normal.
Many thanks, I upgraded from 2.1.1 on two machines and I'm finding that 2.1.5 works brilliantly. Decided to add 256Mb swap files, and this is working well too. No crashes yet! Much appreciated.
Hello
I have Vu duo 2, and I install 2.1.5 BH image. All are fine, but I have one problem: If I shut down the vu+ (dont stand by, shut down) with remote, then I cant power on with remote. The STB start only with power button on device, with remote dont. Why?
On 2.1.4 it was works...
Probably a naive question but I can't see PVR Client manager or any options for ad don? Is there an ipk file I can ftp for this?
