Black Hole Vu+ Duo 2.1.7
XBMC cannot be run into old Vu+Duo box. It's already explained.
Different things are PLUGINS that ports some XBMC Plugins into Enigma2 world.
I own a vu duo2.I have installed this great image yesterday every thing works fine unless xbmc when i try to launch it i got only a black screen.
Thanks for all the great work .
I canot install blackhole 2.1.7 on usb flash with multiboot
when iuse multiboot to istall the image I get this message
( cannot creat virtual MTD device )
but I mange to install open pli with multiboot and it works
what could br wrong ?
Try again until you get it OK.
When I install 2.1.7, can I then use backupfiles that i have on my hdd? 2015-06-06-enigma2settingsbackup.tar.gz or enigma2settingsbackup.tar.gz?
I have the black hole 216.1 image that I down loaded from the adons can I do the same for the 217 image as well
Thans for BH team this great team.
I have a problem after intallation. My cı modul does not work. İt says in te common interfase menu
cam loader then no module found.
Someone help me solving my problem. Thanks
