Black Hole Vu+ Duo 2.1.7
Hi,
How do i uninstall plugins that i have installed myself on this image?
Also does this image re size picons to fit in the box?
I am having trouble with picons working.
The picon appears in the lcd display box but below the channel number i just get a greyed out box as in picture attached.
Any ideas?
Thanks
Hi,
Any ideas?
Thanks
Download picons from BH image server.
No support for re size picons for OSD.
Thanks for this image BH Team.
I've just upgraded from BH 2.1.3. Could someone point me in the direction of a guide to use Open Multi Boot as I've not used this before.
Many thanks
Bonjour,
Ça fait deux jours que j'essais de mettre cette image sur mon vu+duo, sans résultat satisfaisant, je vous pris de me renseigner des procédures pour une bonne optimisation.
Après flash, par quoi enchainer? swap ou picon, epg, multiboot, hdd ? je serai enchanter de les avoir tous, mais j'y arrive pas, trop de crashs.
si quelqu'un pourrai me donner des conseils.
merci!
Bonjour,
merci!
English please in International section!
Yes .. I made this instalation long time ago...what plugin can i use to instal USB files firmware on multiboot?
Enviado do meu A0001 através de Tapatalk
Hello,
It's time that I try to put this image on my + duo saw no satisfactory result, I took you to inform me of procedures for good optimization.
After flash, for what enchainer? swap or picon, epg, multiboot, hdd? I am enchanted to have them all, but I can not do too many crashes.
if someone can give me advice.
Thank you!
Hello,
Thank you!
Without crash´s we can´t give any help support.
You must have on the root of your HDD STB an ou severall crash log´s.
So, ulpoad it here on the forum.
