Black Hole Vu+ Duo v.2.0.0 OE 2
Very buggy image, crashes like crazy.
Some logs in attachment.
ALPA i think you should check what you write or you will only appear a newbie.
Look at crashlogs and you will see that crashes depends by plugin you installed (dddamir) ?
If you install bugged or wrong version plugin IT IS YOUR FAULT.
You are not respecting our work with this kind of comments.
you loose status bh lover.
If I wasn't respecting your work, I would not be here m8.
Yes the image crashed twice when trying to access ddamir plugin (which I installed from BH addon panel)
But image also crashed when tried to access device manager, also when tried to do factory reset.
So if you remove titles from someone who is continuously supporting your board and registered from day1, and in this case contributing with crash logs, in order to make BH images better, than I don't know what I'm doing here.
I'm certainly offended by your action.
You are wrong this image was tested for 1 MONTH from all ADMINS and all beta tester and there are not crashes and problems.
When you tell that the image is "very bugged" you don't respect all our work and i am sorry but you are REALLY REALLY WRONG !! We don't need support form people that write these things.
Well let me rephrase my statement,
It's very buggy on my setup (VU+Duo), and guess crashes on my machine only.
Also enclosed the logs for inspection by the coder.
Im sorry ALPA
I looked at the logs
and I have to agree with Shiro,
most of the errors related to plugin ddamir
then the errors related to System Panel (update image from server )
one error related to skin X2 download
you've been downloading from the server and he was not yet on the server.
So all together there is no image bug in your logs
(except those related to SYS panel
and it is already fixed.You have to update your image)
