Black Hole Vu+ Duo v.2.0.1 OE 2
I have a problem upgrading from v1.7.9 to v2.0.
My set-up is a quad LNB switch with:
1) Astra 19.2
2) Hotbird 13
3) empty
4) Astra 28.2
All working fine on v1.7.9.
When I perform full upgrade to 2.0, and subsequently to 2.0.1, satellites 1) and 2) work OK, but 4) (UK channels) does not.
I get error message "check tuner configuration"; however tuner configuration is exactly the same as works on v1.7.9.
Fortunately, back-up to v1.7.9 works!!!!
Raised issue in 2.0.0 thread and advice was to re-assign Astra 28.2 to sat 4) in config file.
This worked but due to another issue with EPG, I had to reload S/W from scratch.
Same error occurs but now I can't fix
RGO1
Take a copy of your satellite.xml from 1.79 and the manually add it to 2.0.1, make sure your restart enigam2. I had the same problem.
1) Astra 19.2
2) Hotbird 13
3) empty
4) Astra 28.2
RGO1
Try to download new settings via feed.
I had a same problem with my motorised dish on Astra 28.2, Sirus and Thor sats.
It has to do with name of those sats at standard settings after the update.
I don't remember the name right now, but if you look at the tuner settings after the update those satellites have a different name.
I solve the problem by downloading Vhannibal motor settings from the feed .
Edited to my needs and load it back.
I'm very confused.
Opened satellites.xml in edit mode via ftp; didn't change anything; closed without saving.
Went back to tuner config and satellite names had changed.
Now works for Astra 28.2
Quick - where's the backup button!!
Just installed for the first time, and it worked flawlessly. Got all my usual addons installed and working, and a couple of skins that I use. Also an old DVB-T usb tuner I bought about ten years ago works right out of the box, including HD support. Unbelievable.
Thanks a lot guys. BH devs rock!
Hi There . Is the DVB USB tuner menu still available ? Thanks . Sammy
Most of supported DVB USB drivers are already included into Image.
Poweroff your box, plug your DVB USB device and power on the box...
If all works correctly, the device will appear into Enigma2 tuner configuration panel with the internal tuners.
If you have problems, open a thread into DVB-T USB drivers section of this board.
First of all thanks for the great job.
I installed this 2.0.1 image yesterday evening on my duo. my last runing version was 1.7.9 all ok
All looks OK until I tried to load my personal setting.
The problem is the same using deamset or dreambox edit .
The transfer operations goes OK but when I try to access my favorite list some channels are not listed.
If read back my favorite from the box using dreamset the missing channels are present in the editor !!!!
I've tried to load the new image, 2.0 and 2.01 and each time all I get is Starting......
I've downloaded the fiel, unzipped to usb, turned off the box, inserted usb and turned on. Everything looks to be working, reading usb, programming and so on and finally remove usb and reboot.
Then Starting..... and nothing happens.
any ideas on what might be happening
thanks
thanks
Quick format the USB,,,and do the process again!
thanks
Original box or clone?
Hey guys,
im having trouble installing ts panel on this image.
ftp to tmp install ipk in addons restart box and nothing?
any help appreciated.
Hey guys,
WE DON'T SUPPORT ANY KIND OF PLUGINS WHO ENABLES USERS TO DOWNLOAD CAMS AND ILLEGAL SOFTWARE.
Next post like this topic and ban starts.
Hi to all newenigma and new problem to me at least for me ....
If anyone has some time let me explane .. how to insert ccam enigma or TS panel in this new enigma ... 2.0.1 for BH Vuo+ duo ..
Before I prefer over the total commander , tmp now it will not work or I am doing something wrong , if someone can help or explain how to do that thank U to all
Please help. Can't flash, no 2.0.0 and not 2.0.1. I try two new usb stikcs but no way, it is still 1.7.9. What can I do? My duo is original from 2010.​
You haven't read my post posted next to your.
This kind of request break Board rules.
Banned for 1 week.
