Black Hole Vu+ Duo v. 2.0.7
Please try to reflash. I have not simular problem.
Hi !
I've reflash but the problem still there. I do not understand why it doesn't work. I have put an usb stick for universe and change the HDD. One of the erro was "error parsing xml file".
I desactivate CrossEPG and use in manual the EPG who is in the menu. For downloading i must do it for example Rytec Benelux then i must restart the VU and i can do an other downloading.
If a made more than 1 download for the EPG everything hang and i must power off.
I install nothing else, after the fresh installation i try to download and i have immidiately the problem
Hi !
Where do you save your epg data too HD:USB:Flash.
I prefer usb, check you do not have duplicate epg locations (this can corrupt epg data) if you do delete them and select only one location.
Black Hole 2.0.7​
  • Update skin to Matrix10 MX S2
  • New drivers 20131023
  • - Support DVB T2 Tuner(uno, ultimo, duo2)
  • - Support file transcoding(solo2, duo2 : needs an image update)
  • - Fix delivery system bug in vtuner
  • - Fix DDP passthrough(solo2, duo2)
  • [transcoding setup] support filestreamproxy(8003).
  • Update OpenWebInterface
  • [mt7610u] new driver v3.0.0.1
  • [mt7610u] added new driver v3.0.0.2
  • [blindscan] fixed bug in ScanNimsocket function.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash. Black Hole does not support images not installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits Thanks to Pedro_Newbie for Backup script
DISCLAIMER
LICENSE (TERM OF USE)
Great image BH Team, keep up the good work
I cant see any titles off channels,in front small screen of my receiver,i want to know if its only my problem thank you !
thank you !
when u will add internet adjust clock and disable adjust from trasponder integrated on firmware? ....like this:
http://www.schmidhorst.de/QboxhdEnigma2/NtpDate.html
