Black Hole Vu+ Duo v. 2.0.7
Hi guys,
Actually running BH 2.04 and since now alli is O.K.
Need your advice is it worth to upgrade to BH 2.07 and what are significant benefits from BH 2.04 vs BH 2.07
Thanks in advance for your assistance
Hi Guys,
I am new to this tech, looking for help to upgrade firmware from 1.7.3 to new one 2.0.7. I have downloaded the zip file from this thread, unzipped it to FAT32 USB, inserted to front USB port of the box and restarted but nothing happened, box is just started as normal with same old version. Appreciate if some one can guide me plz?
Thanks
Hi Guys,
Thanks
If you have an HDD installed and you have done some backup on it, remove backup or disconnect HDD.
Same operation must be done with USB sticks ... only the USB disk who contains the new image must be connected to start the flash process
Thanks for the reply. I have HDD installed in the box and did a full backup last night (to be safe if any thing goes wrong). Do you mean to to delete the backup done last night or physically disconnect the HDD. It is internal HDD?
Rgds
I have deleted the full backup and personnel back files from HDD, and tried to boot the box from USB but box booted normal again with old version. Any more suggestions please?
Check USB stick, replace it, format it again into FAT32 and make sure you place the correct folder on it (vuplus folder)
On the display appear the "Upgrade found" message?
Hi peeps Is there any issues with this image I have uploaded it to my uno and now when i try to download anything from panel 7.3 it keeps geting errors and even if i try to add plugins manually its saying incompatible
cheers
cheers
If you mean T S Panel ... it's not supported here.
