Black Hole Vu+ Duo2 2.0.5 galaxy
Hello,
where can Rev. A be downloaded. In this thread only link to 2.0.5 and in the update monitor thread no link. I cannot find something like database, too.
Thank you
Hello,
Thank you
To update to Rev A you bust have 2.0.5 on your box then press Green button -> Yellow Button and next select Online Black Home Image update
@angelofsky1980
thank you for your answer. I have installed 2.0.5, but this online option is not a good option for me. I have no wired internet connection and a normal download would be less expensiv (internet cafe). There is no information about the amount of bytes to download (full image or incremental?). With umts smartphone tethering with allready reduced speed (7 kB/sec for the next 2 weeks, very unstable connection. I live in germany and 'wireless flatrates' here a limited to some 100 MB, after that the transmission speed is extremly lowered) it might be difficult to bring the update to end without broken connection. This was the reason, why a asked for a download link.
@angelofsky1980
I'm sorry but intermediate revisions (like the A for 2.0.5) aren't avaiable for separate downloads.
a new error dev blackhole left it on the source and meoinit meobm in the image blackhole 2.0.5 in / usr / src / debug
Problem bei LED-Display von Duo2,die Einstellungen werden nach dem Speichern nicht bei behalten,das System macht was es will,sonst klappt aber alles.
Hello,
can anybody tell me how i put an c ccam into the VU+Duo2? I want to look with a smartcard.
I have tried to instal the software "enigma2-camd-cccam_2.21.ipk" with the usb port at the front but when he is ready he says that there are 0 files installed. I have tried diverend cccams, all get the same message.
