Black Hole Vu+ Duo2 2.1.1
Hallo
ich habe Black Hole Vu + Duo2 2.1.1 geflasht so weit alles ok, mein Problem ist wie kann ich ***** herunterladen oder aktivieren ,wenn wer ein guten tipp hat war ich dankbar
mfg.isniqi
First of all, ONLY ENGLISH IN THIS BOARD SECTION AND NEXT NO EMU HERE
Banned for 1 month.
Hi All ,
I have problem with my seccond tuner. It wont work at all. I chcecked the cables and also my DiSEqC settings. They are all good. Any advice ?
Do you mean the second tuner is not working while recording from different transponder?
Have u activated the second tuner? Try to swap the cables.
If u r using some cam, please try to change the box type in settings.
P.S.
Polish support is very welcome for polish users. Zapraszamy!
P.S.
I did all that.
Tested without the cam.
I did also installed orginal image and then BH.
Original worked fine with two tuners. BH- not.
The 2.1.0 is all ok.
Black Hole 2.1.1
By Black Hole
  • New skin MX SkyLine SE
  • Add new Crypto systems in OSD: Biss, Bulcrypt, Betacrypt, PowerVu (By Ev0)
  • Add parental control in Bh extra settings panel
  • HbbTV enabled by default for Duo2, Solo2, SoloSE, Ultimo
  • Removed mytube plugin (can be installed from BhSpeedUp)
By Vu+
Kernel:
  • Update Kernel 3.13.5(solo2, duo2, solose)
  • Update Kernel 3.9.6(duo, solo, uno, ultimo)
Drivers:
20140715(duo, solo, duo2, solo2, solose)
20140716(uno, ultimo)
  • - Support SoloSE
  • - Switch to Kernel 3.13.5 (solo2, duo2, solose)
  • - Switch to Kernel 3.9.6 (duo, solo, uno, ultimo)
  • - Fix sound drop in radio channel
  • - Improve PIP (solo2, duo2, solose, Needs E2 update)
  • - Allocate more memory to linux (duo2)
  • - Improve media playback
20140721
  • - Fix vfd problem
Misc:
  • Update r8192cu (4.0.2)
  • Update bridge-utils (1.4 -> 1.5)
  • Set sync PCR at PIP mode.
  • fix duo harddisk detection
  • [hbbtv] fix UI position
  • [hbbtv] upgraded to 'opera-hbbtv_0.2.bb'
  • disabled copy libs to sysroot
  • [hbbtv] reduce CPU usage
  • [hbbtv] fix ipc protocol
  • [hbbtv] fix flickering some channel.
  • support seeking the recorded video
  • lcd4linux: update to 4.1-r2
WARNING! DO NOT USE PERSONAL BACKUP FROM PREVIOUS BLACK HOLE IMAGES, AS THIS WILL MIX KERNELS AND LIBS CAUSING MANY MALFUNCTIONS.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
MERCI
Vu + duo2 image. 2.0.8. I have tried all known ways, for me to update to image 2.1.1 without success.
Before image 2.0.8 I could download all the different Vu + duo2 pictures. Now when new images are loaded, so freeze the image, at startup?
(In my Vu + duo no problem to download 2.1.1 or BlackHole pictures.)
Please check your bootloader, and post it's version, you can see this by switching off, at the rear, and starting it up again.
I'm not sure which Black Hole version first required the updated bootloader.
hello :
*- I have a vuplus Duo2 after the flashes 2.1.1 with USB, boot logo remains blue not green were is the problem please.?????
