Black Hole Vu+ Duo2 2.1.1
Hi guys, thx for the BH image.
I use actually BH 2.0.9 can I update my VU+ DU02 without loosing my config ( channels, ***** config etc...) ?:notworthy:
Thx.
Thx.
You should read our Board rules.
No emu support allowed here. Banned for 1 week
A lot of thanks for this wonderfull image.
Fast and also good looking.
I only had some problems with installing (not allowed to mention)
So I tried to install it in flash and that worked perfectly.
Did I allready say thanks?
Well thanks!!!
Well thanks!!!
Very sad but after a while this version shows a malfunction.
When I make some recordings the signal on several channels disappear and returns when I stop the recordings.
So I went back to an older version which works just fine.
i love this version of the black hole but cannot understand why the the auto timer is not integrated on epg so could add the timer in one click instead many. the vix is like that. the black hole picture it is superb and no other image can give a so vivid and superb picture. congratulations team
I have factory reset and reflashed BH 2.1.1 twice and same problem exists......
1. Skin remains blue in colour as if from previous image, not MX Skyline SE shown at begining of thread
2. I have 2 dishes setup as before which worked well, however, when I have timed a recording on freeview chanel it starts at programmed time but wont let me watch something else in particular using Cc.am
Any help would be appreciated
In particular take a look here http://www.vuplus-community.net/rules.html
No emu here.
Banned for 1 week
To avoid further pain in the neck I installed version 2.0.9.1.
It took me about 5 minutes to install and to fine-tune it.
This version is allmost simular to 2.1.1 and gives no problems.
So I'm very happy again.
hi guys,
clean install of latest version over 2.0.9 helped - no problems but one:
stream to VLC won't work, doesn't matter that trying to stream through Web Interface or iDreamX getting the same error that VLC can't open stream.
any idea how to fix it or its just a bug?
cheers
Kris
Hallo
ich habe Black Hole Vu + Duo2 2.1.1 geflasht so weit alles ok, mein Problem ist wie kann ich ***** herunterladen oder aktivieren ,wenn wer ein guten tipp hat war ich dankbar
mfg.isniqi
