Black Hole Vu+ Duo2 2.1.1
Hi to all,
like everyone of you, i tested the latest firmware, and finally after an hour decided
to go back to previous version.
I setup everything after flashing with new firmware, and then when i do a lan exploration do discover all
other device on my network, it finally find them but after that impossible to get acces to the share folders ,
the thing happen both with CIFS and NFS share.
I have to add that nothing change to my share folders privilèges or rules, because as soon as i came back to previous version
everything came back automatically.
I don't understand whaat could be the cause , i also have to admit that i have for various problem with BH event with older
receiver like my previous Ultimo, today i use a DUO2 with four tuners. Second phenomenon that regularly happen is that i have
to rescan moreless everyday to find back my Nas from inside the lan exploration menu , each times it desapear.
Well, i don't want to blame BH coders , but just wanted to give my feedback .
sincerly Joel from Brussels
@angelofsky1980
Thank you very much for your answer.
I have two satellite dish and each tuner in your set. I have another firm with MeoBoot and goes perfect, I can record and watch another channel sat. just gives me errors with this version of BH, with the previous version of BH was going perfect
thank you
Hi to all,
Could you show screen shots of how you have it setup ?
I have all my box's sharing to NAS and HDD in my Duo2 using CIFS and have no problems, It may be worth setting up a new thread to try and get the help you need if you wish.
"opkg upgrade" replaces fancontrol2 plugin with a version that doesn't work
(the current version was installed from the "BlackHole Addons" tab)
root@vuduo2:~# opkg --noaction upgrade
Upgrading enigma2-plugin-extensions-fancontrol2 on root from 3.999+git4839+1d7569b-r0 to experimental-git20110215-r10-bh2...
Downloading http://feeds.vuplus-community.net/2...2_experimental-git20110215-r10-bh2_vuduo2.ipk.
smartmontools was autoinstalled and is now orphaned, removing.
Removing package smartmontools from root...
après avoir installer cette version avec Succsé et après avoir éteint le duo2
il ne veut plus démarrer il s’arrête sur la lampe blanche seulement.
le ventilo aussi ne marche pas
étape d'instalation:
1- Duo2 CFE V2
2- image - vuduo2 - 20140729095257
3- BlackHole - 2.1.1- vuduo2
après plusieurs tentatives de mise en marche rien ne ce passe
voila une vidéo explicite
c'est pas la mienne mais c'est mon cas
SVP aider moi que dois-je faire?:cry:
@mimi73 : English Please in this section.
I'm sorry this is my first participation
after installing this version with success and later after turning off the duo2
he does not want to start it stops on the white light only.
also the fan does not work
step instalation:
1 - CFE Duo2 V2
2 - Image - vuduo2 - 20140729095257
3 - BlackHole - 2.1.1-vuduo2
after several attempts to start it nothing happens
here is an explicit video
this is not mine but in my case
Please help me what should I do
step instalation:
1 - CFE Duo2 V2
Unplug HDD and other USB if you have any plugged in, then try and flash an original image from this link
http://code.vuplus.com
I would also try a different USB for flashing.
1- Duo2 CFE V2
Re installer une fois encore la meme version mon ami ou simplement reflasher the box il n y as pas d'etape il faut suivre comment insaller
problem to chaine HD crypté not work PIP to my V+ DUO2 Help me !!!!!?????
I detected that the problem is in compatibility with the emus. If you use ***** only version 2.3.0 works good. With others versions internal readers, pip function, and record a channel and view other channel, all this fails.
You MUST read our Board rules.
Banned for 1 week
1- Duo2 CFE V2
J'ai pas dit qu'il ya des étapes .. j'ai simplement expliquer ce que j'ai fait avant que je rencontre ce problème de lampe blanche
comment je peut le reflasher s'il ne démarre même pas et ne détecte aucun périphérique USB?
Merci pour ton soutien
