Black Hole Vu+ Duo2 2.1.4
You must check first if your Internet connection works,
if not check in network configuration >> Gateway
then check your account
and Inadyn configuration[/QUOTE ]
Ok problem solved......in the last line changed from System setting from xxxxxx.org to xxxxxx.com
Thanks Matrix again. :thanks::thankyou:
I don't have Personal Backup (I Have Full Backup). Can't find it in the list of available plugins.
I can find it via package manager (opkg)
bhpersonalbackup - 1.0-r5 - bhpersonalbackup version 1.0-r5
Why are this not show in the Black Hole app list ?
menu
backup
personal backup
regards
I Still have BH 2.1.0 but the above is there : Press Menu/Backup Menu/Black Hole Full Backup OR Black Hole Personal Backup Or Black hole EPG Backup. Can someone explain the differences or advantages when upgrading to a newer BH image the backing up before upgrading to a newer Image by either using Black Hole FULL Backup or Black Hole Personal backup. Which one is better a full or Personal back up
Bh personal backup is in main menu box no in aplication list [ i think you ask about this option ]
Becouse im no see plugin with name like this on feed.
