Black Hole Vu+ Duo2 2.1.4
On your remote control:
Press <MENU>
on Setup press <OK>
On Service Searching press <OK>
On Automatic Scan you get this Screen:
Yes I did all that but nothing happened. I don't understand when I install other firmware this will not happen to me but only bH does this.
If you have got a screen like this ---> press <OK>
Best regards
Press <MENU>
on Setup press <OK>
It doesn't work but the two other images that I burned into my box check my Diseqc first and find the satellite.
Best regards
Hi,
how to disable "fade effect in osd" in this 2.1.4,..
I try in Settings,..but cant find,..
tnx_
is it possible to disable-remove from ftp inside Image "fade effect",
or its only choice to downgrade to BH 2.1.2,2.1.1,..
please responde,..
regards_
thanks for replay,..
thats option its only for bh-2.1.5 or beta1/2 with Open GL-option inside Image,..
I think thats inside "InfoBarGenerics.py",..but not shure,..
anywhey tnx for help,.
@opala
