Black Hole Vu+ Duo2 2.1.4
Hello, anybody knows, why my box (bh214) power on every night from stanby itself? no timer or scheduled crossepg set up. Only HDMI cec is on to work with tv. it could be a problem? im switched off every night and im woke up that the bix is running.. but why?
Did you set the Wake-on-LAN parameter? if yes, then indeed it sometimes wakes-up randomly .....
GS
GS
No, i did not- i checked every setings, regarding the time- ::cross epg, lcd,lan, timer-- switched of the cec now- but noting helps
Hello,
I saw a few weeks ago BH 2.14 image and thought that's something I like. So I read a bit here and on other forums about vu+.
This week I've got my vu+duo2 (2x dual dvb-s) put a 2.5" hdd in and flashed it.
BH 2.14 is running nicely ! thank you for the good piece of software !
I have a few questions:
1) how is it possible to update "vuplus-dvb-modules-vuduo2-3.13.5-20150109" or similar files ?
2) Can I use more than just 1 PIP with blue button ? I'd like to have more of them on screen and can I have sound switch from main picture to PIP ?
3) When I try to update within BH I get nothing new found...are there updates available ?
4) I had to use the full backup ... that I copied to USB stick because plugin VPS ( I thought it's similar to the old VPS signal on video recorders cassettes VHS) crashed the BH on every reboot.
a) Is there a way to use the backup on hdd or do I have to use USB stick to flash it back ?
b) How can I delete a faulty plugin from box so I don't need to reflash it when trying something new?
well, many questions and I hope someone can help me.
Hello,
1) manually. Take a look to http://www.vuplus-community.net/board/threads/how-to-install-new-drivers.2363/
2) I think no
3) not yet
4) a) Uhm ... I think no. Only USB flash
4) b) ignore the green screen and log into your box via FTP and make the clean
Black Hole 2.1.4​
What is new in Black Hole 2.1.4:
All models: Full HD Skin ready.
The 1920x1080 framebuffer support recently introduced in Vu+ drivers has made it possible to use full hd skins. But many parts of the enigma2 gui are hardcoded with fixed fonts and itemheight.
This causes fonts at 1920x1080 resolution to appear far too small. All these gui parts have been re-coded in Bh 2.1.4 to support larger fonts and itemheight in case of full hd skins (thx to Matrix10)
Solo and Duo only:
The 1920x1080 framebuffer support has required extra Ram usage. For this reason the old Solo and Duo models do not have enough free ram to run the curent images with these new features.
In Black Hole 2.1.4 we have included ram compression (zram) that increases performance by avoiding paging to disk and using a compressed block device in RAM instead, inside which the paging takes place until it is necessary to use the swap space on a hard drive or usb stick. Since using ZRAM is an alternative way to provide swapping on RAM, zram allows Linux to make more use of RAM when swapping/paging is required.
misc:
  • drivers:
    201412005(zero, solose)
    - Improve PQ(zero)
    - Adjust LED brightness(solose, zero)
  • update driver
    20141201(solose)
    - Fix analog audio(solose)
  • drivers: 20141126(solose, zero)
    - Fix booting problem(solose)
    - Support LED brightness control in idle mode(solose)
    - Support LED brightness control in normal/idle(zero)
    - (Brightness can be controlled in Menu -> Setup -> System -> Display Setup)
  • New Skin MX-Black
  • Meoboot update: Fixed the issue of non working usb drivers in images in multiboot.
  • About screen: Add drivers version, kernel version and Cpu info.
  • Bh Full Backup update.
  • OpenWebInterface update.
  • WirelessLanSetup: add quote to wpa_passphrase for password.
  • Black Hole Swap panel: Allow to create swap files upto 2 GB.
  • Black Hole Swap panel: Update descriptions (Thx to Ev0).
  • Solo2: fix ethernet problem in some Gigabit switches.
  • Solo/Duo: implement Zram
  • Librtmp update.
  • Added to feed: livestreamer, livestreamersrv
  • Added to feed: python-mechanize python-futures python-pip python-requests python-singledispatch
  • [PATready] 'cnt' is increased twice, causing failure to obtain a single pmtpid.
  • [VirtualKeyboard] fix default layout (en) must be "qwerty"
  • Bh Device Panel: fix meoboot mointpoint only when meoboot is installed
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash.​
Black Hole does not support images not installed in flash.​
Please note that of all images Black Hole now has the best epg system:​
- Integrated OpenEpg​
- Rytec dedicated epg.dat​
- New system epg.dat outside.​
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.​
Community members can then download it from our servers.​
This feature provides other benefits such as:​
Increase download speed of EPG​
Download EPG from any channel​
Schedule the download of EPG decoder even during standby​
Users can customize the providers using Add / Remove function​
OK button = Skin with simple information​
OK button x 2 = Extra Info Skin​
Blue button = Black Hole Blue Panel​
Blue button and then Red button = Black Hole Epg Panel​
Blue button and then Yellow button = System Monitor Panel​
Blue button long press = Extensions​
Yellow button = Audio menu​
Green button = Black Hole Green Panel​
Green button long press = Subservices​
Green button and then Red button = Fast Plugin Setup​
Green button x 2 = Fast Plugin​
Button Red short press= access HbbTv functions​
Button Red long press= Red Panel (Parallel Universes Teleportation)​
Addons​
Green button and then Yellow button takes you to:-​
Dedicated server for BlackHole addons​
Download and install additional packages from the Black Hole server​
Infobar / OSD​
Analog Clock Gui​
Channel orbital location​
Advanced Tuner Info: Sr Freq Pol Fec​
Signal SNR, BER​
Infobar picons​
Characteristics of BlackHole Panels​
Blue Panel​
Extra Settings​
Black Hole Speed Up​
Black Hole Cron Manager (Manage schedules)​
OSD Settings (OSD configuration)​
Devices Manager​
Usb Format Wizard​
Kernel Modules Manager(Kernel module operator)​
Inadyn Settings (Configure Inadyn)​
Swap File Settings (Configure File Swap)​
Hard Disk Settings (Configure Hard Drive)​
OpenVPN Panel ( OpenVPN Panel)​
Samba / CIFS Panel ( Samba Panel)​
NFS Server Panel ( NFS server Panel)​
Telnet Panel ( Telnet Panel)​
FTP Panel ( FTP Panel)​
UPnP Client Djmount​
UPnP Server Mediatomb​
UpnP Server Minidlna​
Pcsc Panel​
Tuner Server​
Network Browse & Mountpoints​
Info Panel​
1 - Gui Setting (Gui configurations)​
2 - Service Information (information system) ​
3 - About (info) ​
Memory (Memory) ​
Space (capacity) ​
CPU (processor) ​
Process (process)​
EPG Panel​
Global settings (global settings EPG)​
Setting Provider (ISP settings)​
Green Panel​
Addons (added)​
Addons Download Manager (Manager for package downloading)​
Online Feeds Settings update​
Online Black Hole image update​
Manual Install BH packges (Manual installation of Black Hole packages)​
Manual Install IPK packages (Manual installation of IPK packages)​
Addons Uninstall Panel (Uninstalled packages)​
Black Hole Statistics (See connections, top downloads and more)​
Red Panel ​
BH Parallel Universe Teleportation​
BlackHole​
Avalon ​
Chaos​
Ghost​
Credits​
Thanks to Pedro_Newbie for Backup script​
Thanks to the group of Beta Testers.​
Thanks to Rytec for providing us with the server with all epg.dat files.​
Thanks to MaxZ4 for Integrated EPG loader.​
Thanks to Skaman for Cross EPG​
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.​
Thanks to Reinh@rd for the file satellites.xml.​
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code​
DISCLAIMER​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.​
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
Hai guys I got a new box xtrend et9x00 in addition to Dou2 I have is it possible to have blackhole for et9x00 as I'm very happy with bh on dou2
