Black Hole Vu+ Duo2 2.1.5
Thanks. Will BH image support Chinese language?
Black Hole 2.1.5​
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
Note for Meoboot and OpenGL images:
Because OpenGL images have a different boot procedure and the framebuffer is loaded at the end of rcS it is not possible to have the Bootmenu.
For this reason to change image you have to go into Meoboot plugin, select the image you want to boot and click on "Boot Image" button.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
... regarding your STB ... note: don´t know the model ...
Check your tunners config --> Do a complete search --> restart your STB.
Thanks,
Sorry, should have stated it's a Duo2
Which media file formats are supported by xbmc+duo2 combination?
I will do as you suggest, but it will only be repeating what I just tried. Will do it anyway, if it does not work I will otherwise step down to an earlier version.
Hi,
Have upgraded to 2.1.5 and now hbb work on Danish television, before it show 2 sec and then freezed and had to be rebootet. Now it can show hbb, but exiting from hbb on Danish televison then remote control become unresponsive and have to reboot. The web interface control is still working. What kind of logfiles you need to look into this.
Thanks,
Almost ... all type of media files or streams!
regards
I have blackhole hole 2.15 installed on vuduo2, everything was working fine. Now when I launch xbmc everything goes black, and xbmc wont start., I have to restart in order the vuoduo2, thanks
Do you have a internal hdd for media installed, usb external hdd on your Vu+ Duo2 STB?
If so ... how it´s mapped?
Hi to everybody!,
i installed the new release of Blackhole 2.1.5. It´s so pretty!. but i have a one problem with picons!.
I put my picons ( in format .png ) 220x132px into folder /usr/share/enigma2/picon/ and show perfectly into LCD screen but don´t show in infobar...
I try to put into /media/usb/picon and don´t show again... any fix?
Thanks for your help!!!
Hi to everybody!,
Try to see if the folder /picon/ on /usb/media has attributes 755 and the png files too!.. Don´t forget to restart the STB.
Note: And of course, if the usb key is mapped, like /usb/media
Try use both locations (at the same time), not only one. Also, remember about the correct picon path in LCD4linux settings (/media/usb/picon/).
Hi to everybody!,
Sorry my mistake ---> /media/usb
I have one problem related to audio in some HD channels. It seens that the image cannot decode the audio pid, so these channes have image but no audio, i verified in audio menu and there is no audio track, I installed other image (with OE2.0) to compare and there is no problem, audio is fine. This problem only happen in HD channels. Anyone have one problem like this?
What HD channel is? What satellite? What iamge are you using? Dolby digital amp system used?
For example, Cart@@n Netw@ork HD, it´s cable channel (not satelite), I tried BH 2.1.4 and BH 2.1.5, both have problem. I´m not using Amp, just the TV speakers. I think it's not related to audio output (like you asked about the dolby amp system) because in the audio menu (yellow key) there is no audio track for these channels, and I also have other HD channels working normally. The problem happen only in a few HD channels. I did one test with the new OpenATV and channels are normal, all have audio.
Probably the TS stream contains an unknown audio track type not mapped into E2 sources.
You can try with official Vu+ image and, if the problem persist, open a bug request directly to Vu+ (www.vuplus.com) with all data in your hands and Dev team should try to solve the problem with your cable provider.
Thks, I´ll do that. Just one doubt, I saw in code.vuplus that they have 2 kinds of images (1.6 and 2.1). Wich one I should use to do that? This 1.6 is related to OE1.6?
Black Hole 2.1.5​
Black Hole 2.1.5​
  • fix keymap bug
  • fix channel skip
  • update Usbtuner
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
  • fix keymap bug
  • fix channel skip
  • update Usbtuner
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
best image ever . Thx BH Team Keep up the good work . To the next
Hey, I don't know if I can talk about this, but I'm just asking
Does this OS support BISS ke*s? How can I use them?
If its not allowed please PM me with the info :)
