Black Hole Vu+ Duo2 2.1.5
Hi. I attach a couple of log files about two system crashes on my Black Hole Vu+ Duo2 v2.1.5.
Hope they will help you to improve it. Cheers
  File "/usr/lib/enigma2/python/mytest.py", line 201, in processDelay
    callback(*retval)
  File "/usr/lib/enigma2/python/Screens/TimerEntry.py", line 247, in finishedChannelSelection
    self.timerentry_service.setCurrentText(self.timerentry_service_ref.getServiceName())
  File "/usr/lib/enigma2/python/Components/config.py", line 311, in setCurrentText
    i = self.choices.index(self.value)
  File "/usr/lib/enigma2/python/Components/config.py", line 206, in index
    return self.__list__().index(value)
  File "/usr/lib/enigma2/python/Components/config.py", line 182, in __list__
    ret = [not isinstance(x, tuple) and x or x[0] for x in self.choices]
IndexError: string index out of range
The first crashlog not contains any useful info but the second have a readable error but seems related to something about reading some DVB services in your channel list.
Have you tried to scan manually with your tuner and not using a pre-made settings?
I was doing some different tests with this new release, some with and some without pre-loaded list channel. Actually I didn't notice when the two crashes arrived if I was using the manual or the pre-loaded list channel.. Ok, next time I will do more attention about this step to help you. Thanks anyway about your great job
Hello guys,
anyone is able to update OpenVPN to a more newer version?
The one included on BH as some years now and im getting some bugs, from time to time it shows Real IP instead of the VPN one that is on.
The tunnel is active but its not working 100%
Hello from Georgia,
how to read EPG on Georgian? Just added Sylfaen.ttf to /usr/share/fonts but nothing happens
with web-interface can see EPG, bot not with reciver
Hi, I have installed the black hole 2.1.5 and worked well, but I gave several problems and I have loaded a full backup I had done and since then takes forever to react, more than two minutes to go from channel or enter the menu, I've installed several times and still the same, someone can help me out to see who can be? Thank You.
It seems this version (BH2.1.5) is not compitable with previous backup (except channel list). Please check the Original Image Note.
Mediaportal 6.8.0 BH not working, only the 6.7.4 Version. After Update to 6.8 you can open Mediaportal, but after clicking any film the box is frozen.
Use HQ 4,5 or 6 skins for mediaportal from BH image server .I have update this skins .
And for old format skins 1080x720 you can use all older skins with Mediaportal.
For 1920x1080 format for now only HQ 4,5 or 6 skins from BH server
Thank you very much for the fantastic work.
I have two problems:
1) sometimes, when I want to use the "breeding animal" the image is blocked and I have to restart from the button of ignition.
2) from the XBMC I cannot enter for samba, he finds the workgroup but he asks for user and password me to enter a computer of the network, I do not have user and password, from another device I enter perfectlye. Directly with the vu + I have several units mounted and enter without problems.
Thank you
Is anyone able to get plugin enhanced media centre working in 2.1.5? It installs but won't work for me.
Don´t know that ... Enhanced Movie Center ---> Works:
Download from the feeds --- via addons ---> Install only version 3.7.4 Beta Version and configure the setup on the plugins panel.
1) sometimes, when I want to use the "Media Player" the image is blocked and I have to restart.
Thank you
Not sure what "only install in flash" means"?
Anyway, placed the files on a USB, into the front USB slot, rebooted, installed, configured network and tuners, channel search and found 1000+ channels.
But:
-Message "Starting GUI" never goes away in the lower right of the screen
-When trying to see a channel the channel list is empty.
I tried youtube, and it works fine, also work fine to play earlier recorded stuff on the internal hdd, xbmc starts but play nothing on my drive except pre recorded .ts files
Any suggestions?
But:
Any suggestions?
Q: Not sure what "only install in flash" means"?
A: That you must only install in flash memory, i.e., you can´t install, on hdd ( via meoboot ) --> The image you install on flash for example: Blackhole 2.1.5 ( regarding your STB ... note: don´t know the model ), can´t be installed out of flash.
Check your tunners config --> Do a complete search --> restart your STB.
Best regards
