Black Hole Vu+ Duo2 2.1.5
After I installed the BH 2.1.5, can I still use the channel list which is backuped by DreamEditor? I heard the BH2.1.5 has rewritten many new functions. I perfer to install all plugin freshly, It much more easy than install a backup and sorting out the problems which happens (if). But it is very difficult to edit my channel list, therfore, I need to backup my channel list.
My experience, the channel list was the only thing I could restore from 2.1.4. Most probably, you can also use it without any problem.
Thanks, Usually, I restall the channel list without any problem, but this time, it says that BH 2.1.5 has many new codes, I just warry whether Bh has changed the format of channel list. Thank for your information.
I use DreamBoxedit for years without problems
So NO PROBLEM
Hi, great work with 2.1.5, I have one issue I'd like to share that may be of help, I'm sorry I don't have a crash log as it doesn't actually crash. Installed 2.1.5 from scratch, used no back up. Problem occurs in trying to access the recordings, the little icon like a playing card comes up with the line through it and as a result of pressing this button all buttons give the same result and am stuck on the channel I'm watching. This only happened after I downloaded a range of plugins, was working fine before that. I reflashed a second time in case it was just a glitch but same happened, tested it before downloading my usual plugins and worked fine, after download plugins it bricks. Hope this means something and can be of help... Thanks and keep the cool updates coming :-)
It's hard to know without log
or plugin name that is causing the problem.
So install clean image
and test plugin one by one.
Ok, thanks, will do during the week as back to work tomorrow and do as suggested, there is only about 6 or 7, Bonjour, Autotimer, Seek scan, Series link(cant remember exact name), Merlin Graphic EPG, DNLA server and maybe two more. Will let you know as soon as I've done reinstall. Thanks again :-)
I flashed 2.1.5 image then I found out that my backup not working :( ... I go back to 2.1.4
Becouse is open gl driver in this version image; you mast setup all from begined
And no mix images with opengl and standard drivers
Thanks!
but i have 2 questions.
1. why doesent the openwebif have my favourite channel lists, i cant seem to find the anywhere when i enter the webif?
2. is it possible to get a bigger picon in the osd down the left?
Hi friends, is my first post and take the opportunity to greet you all and thank so aportais the rest. I have a problem with the vu + DUO2, I have the black hole 2.1.5 and all data of white which is current and in fact when I look in the server is ok and the green light, but I did not open the contracted channels of course I have the data in the box, rsa and others, but there is no way someone can help me to see if I make it work? A greeting and thanks.
?!? RSA? Can explain better what are you trying to do?
When choosing a channel from Favorite list, the picture on my TV is scrolling from left to right horizontally. The same when switching to Favorite list. I have never seen this strange thin on any reciever and img before. ????
