Black Hole Vu+ Duo2 2.1.5
Thanks a lot. I will install it tomorrow and let you know if this-one is OK.
Sadly I really don't like the interface. For me its to much W8 like. But that is personal of-course. But the worse thing is that the signal on the channels suddenly went down with 25%!! So I installed the backup I have of version 2.0.9.1 and everything is all-right again. Very strange. And because version 2.0.9.1 has a very good and tranquil interface to me, I keep it to that version. Not every renewal is an improvement.
Hi. would like to update my Duo 2, But I am not sure what you mean by save personal settings by software manager. What and where do I find it. I normally just select it from the menu, or is there some other software I need to install on my pc.
Many Thanks for your time and effort
I've the same question. Could anyone plz explain it?
Brillaint update, the best I/F by far. Your hard work there does not go un-noticed... The OpenGL is superb... and XMBC/KODI too... again brillaint... THE reason to buy a Vu Duo +...
Did notice that after my backup restored (backup as per above post - made on 2.1.3 - using first image install prompt) - that my network settings did not work (they were all correct, just didnt seem to function - I use a fixed IP) until after a (long power button push) system reboot... All fine then...
Dan
Hi Thanks to the BH Team. One question, i want to restore my personal backup after fishing to 2.1.5, but that´s not possible..is that correct?
Hi
To back-up your settings go -MENU - SET UP - SOFTWARE MANAGEMENT - SYSTEM BACK. When you install the hew Black hole as part of the start up process it will ask you if you want to restore your settings, just answer yes.
It's written in release post:
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Thanks for new release!!! I have a couple of issues though.
The new skin and old ones fly inn from the side. Maybe cool on a mobile screen, but if you project large image to a wall it makes you sick. How can one change this fly in???
Also I have tried to test it up towards cabled connection and also towards my mobile 4G. This is not easy for me at least. I doubt it will be easy for others as well. Could you make this setup a bit more intelligent so you do not have to go in circles all the time?
Again thanks a lot for all your good work.
Is it possible to change Rome to any other town in weather forecast plugin?
I will answer to myself. It is language problem. MSN does not support all language versions ( in my case serbian )
When I set my box language to english, it is possible to change town.
go in menu. system. scroll to animation and ok on disable animation. that's it
Black Hole 2.1.5​
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Known Issues: Xbmc External Player not working yet.
Note for Meoboot and OpenGL images:
Because OpenGL images have a different boot procedure and the framebuffer is loaded at the end of rcS it is not possible to have the Bootmenu.
For this reason to change image you have to go into Meoboot plugin, select the image you want to boot and click on "Boot Image" button.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
siete fantastici grazie
